"rusty ol cuda" nightmare on any street wheelstander project
well the pillow block is now installed and she's sitting at ride height on stock rear springs, no helpers no blocks, she actually sits a little higher but there is a limiter in their temporarily, now I'm on the hunt for crossover u joints so I can move on to the next step
YaHoo Waggs!Your wheelstander project is moving forward nicely!Your an inspiration for any Early-A build.Keep up the great work!:cheers::cheers:
Sweeeeeeet , you sure did raise the back transfer case and nose down the engine. how much are you going to have to wedge the carbs to bring em back to level, did you get your angles on the drive shafts that you were shooting for? that's really going to be awesome when you get it going.
by the time I get the front wheels in the air the nose down thing won't be a problem and yes I got good angles on the pinions, lookin good there so far. on the original hemi under glass with carbs they had some issues but the engine leaned to the rear so maybe what I did by going nose down will help it a lil bit,I am able to change that angle readily if needed. at this point it's an experiment. if I can pull this off with carbs great...if I can't we already know it can be done with fuel injection
ok so i been scarce on here.......I was busy :D
ok shifter is mounted and hooked up, changed direction on the seats so high backs it will be, installing the cross bracing and making seat mounts now
Curtis sure you don't want to come up here???? Great work.
more slow progress, brakes are almost ready to bleed, gotta go pickup the driveshaft and some more parts here in a Lil' bit
Looking good! Are you gonna run the factory k-frame and suspension? I Think the original Hemi under glass cars had a straight axle, would give you less weight up front, probably better view when you have the front way up too.
I'm gonna do like I seen in pic's and run the stock k member and suspension..if it cant carry a wheelie with the engine back there then I need more engine :burnout: got a Lil' More progress today
ok so its startin to have a stance???
ya think???
