I got two rotors off '74 Duster that hadn't been moved in over 15 years. They both had enough rust to require some 'remedial' action so friend glass-beaded them. After, still over 1.00" thick so cleaned thoroughly and installed with good bearings on my Challenger (as that car had rotor diameters down to minimum - 0.940" and significantly o.o.r.) The Duster rotors absolutely straight and fresh surfaces.
Suggest you pull each front wheel off and 'mike' rotors for thickness. If rust not bad, remove calipers (without disconnecting lines) and do a hand-sand of each surface. Check for o.o.r. and dress pads (unless too thin to re-use), then, re-install and do a complete fluid change. This is all the very least I would do.
Oh, and could be a good time to do a thorough cleaning and re-packing of bearings (if it's been long time).
