Salter Racing Engines, 383 502 Hp & Tq
FWIW, the numbers IMO were surprising for such a small camshaft. The added rocker ratio was a big help. But it’s still a small cam duration wise, non the less.
I don't want to hi-jack this thread but...I should start my own. So with the power of the internet/forums....I will. J.Rob
Don't worry about hi-jacking, itls all good, I don't mind, talk about whatever you want :)
Any idea what piston and rod are in this thing? If it’s a heavy stock piston, it’s even more impressive he made 500 hp.
The 1.7 rockers are giving it a “big cam” lift. 109 L.S.
This effectively is a larger cam than the cam card showed. The winner guessed closest to the lift with 1.5 rockers. Which were not used and irrelevant.
Wonder how many street miles and cold starts that 600 lift cam will last.
What I have noticed about the 'stroker' engines, no matter the brand: 400 SBM, 383 Chev, 347 Ford. They all produce more HP than non-stroked engines of the same cubes/family........and......they all have smaller rod/stroke ratios.
This was a stock stroke 383 in this test.
I wouldn't say that's entirely true, that a stroker and or displacement automatically adds power, especially when you look at in hp per cid.
Displacement automatically adds power by increasing tq, all else being equal. Hp per cid is going to depend on what other mods are done.
IDK, but, he gave you the ratio and the head used. Grab a compression ratio calc and start figuring. Then perhaps line it up with a piston on the shelf if you can find one for a MoPar 383. That’s the tuff part.
It does make the cam bigger by a small amount. The real plus is the increased intensity of the rate of lift.
I’d say it depends on rocker geometry. The valve guides are effected by the valves not going straight up and down, so the rockers have to be right on the money for longevity.
After that, spring life is questionable. Quality springs vs not so good springs etc….
I otherwise don’t see a problem.
Adds torque but gives up rpm, it takes both to make power.
More torque at a lower rpm doesn't necessarily equal more power.
2nd issues what would be an fair comparison, what's considered same/similar level of build between two engines of different displacements and bore, stroke and rod ratio's ? Aka, 345 VS 416 or 355 VS 383 or 306 VS 347 etc.. Or different brands and or families ?
Ramm,
I believe it was you who built a 360 ci with EQ heads some years ago that was making 500 HP.
Do you have a link to compare the dyno results between the two engines?
