Sb elecric water pump design. School me on backing plates?
Caco2120
Marion
I may be overthinking this. In fact i must be since all mopar sb water pumps i have seen have backing plates.. BUT....is this not a recipe for cavitation?
The timing cover has a smooth recess for a WP impeller on a standard pump...
With an electric, you mount a smooth plate, but this does not block off the smoothed timing cover passage entierly. Even the moroso, which looks like it would bolt right to the timing cover, uses a backing plate...
Do electrics just blast SO much water that this gap doesnt matter? I cant help but picture this gap between the timing cover and backing plate holding air and all kinds if problems.
No doubt overthinking...just wondering how,why, and am i the only one to ever question this.
To answer your question, no it does not. The plate blocks everything but the passages which flows directly onto the impeller of the electric pump. I haven’t ever had a cavitation problem with my CSR pump. Other than when you first fill the radiator, my CSR takes a bit of priming. But once it starts going, it never stops or cavitates.
Yeah. You're over thinkin it.
