[SOLD] SB LA cam retaining plates, bolts and washer and bolt for the cam eccentric
physixx
Edison, NJ
2 sets sold. One more left.
I have for sale 3 SB LA cam retaining plates with the attaching bolts along with 3 timing gear to camshaft special attaching washer and bolt. The 340 engines came with a 4th bolt on the cam retaining plate that had a hole drilled in the center for oiling. I don’t have them but I have taken a similar grade 6 bolt and successfully drilled my own hole down the center. Worked out great. The 360 engines had a pointer type thing that allowed oil to drip on the crank timing gear for lubrication. Unfortunately, I don’t have any of those pointer things either. I would like to get $20 for each cam plate, three bolts and cam special washer and bolt set. Plus the shipping.
Ken
Edison, NJ
I'll take a set how much shipping to 19522? isn't there a convex washer also that goes with the cam bolt?
