[WANTED] SBP steel wheel size 14 x 5 1/2
cuda4frank
Active Member
Delaware
Rating - 0%
0   0   0
In search of a 5x4 (SBP) steel wheel 14x5 1/2. Only need one, but will take a pair.
I just moved a bunch of stuff around and I think I saw a pair of these in the pile. If you're OK with the idea of having to ship these I'll take a look later today.
Well phooey. I dug them out, they are 14x6 but they are 5x4.75 bolt pattern. I have no explanation on this one, I would have sworn these came off a 78 Volare I parted out. Sorry...
Thanks for checking, appreciate it!
It's SBP for certain because it fits on my 64. I just can't use it because it won't accommodate my single piston disc brakes
I might have this. I have a 64 Valiant Signet 200 with small pattern up front. I will be going to big pattern discs to match the 8 3/4 we put in the rear. The only problem is that all my rims still have tires on them.
