SBP studs for SSBC rotors
austin tx
I am having a very hard time finding wheel studs that fit properly on my SSBC rotors.None of the factory wheel stud applications fit properly.Does anyone out there have any ideas?I am using the small bolt pattern set up.
Hi Roy,
My SSBC rotors came with both size studs installed and I just had to knock out the studs I wasn't using. I'd give them a call and see what gives....Brian
I still need 5 SSBC small bolt pattern wheels studs.I bought 5 from a FABO member and now I just need five more.If anyone of my FABO brothers outhere have a set that they are not using I will gladly buy them.Thesse SSBC disc brake conversion kits come with big bolt and small bolt wheel studs.I bought mine set up second hand and they did not with those studs.
