SBP Weld 5 Prostar or similar?
lee01
Cantley, Qc, Canada
Anyone knows if the Weld Prostar (or similar from other brand) 5 star wheels were ever made in small bolts pattern?
or will I need sbp to lpb adaptor?
4.100 mm will work. I saw a set on a neon. don't know if they changed the pattern or if they are available in 4.100 , They had slicks on the front and runners on the rear. May want to check out that avenue. I bolt older 5 lug Omni wheels right on older darts. plus various other after market wheels. you just need to use standard thread lugs. Not metric.
Centerline makes wheels that work. Call them they will custom make almost any wheel you wish in SBP. I just had it done.
Look just like billet specialties.
