Selling a set of Scarebird disc brake conversion mounts for SBP 60-72 A bodies with 9" drums and no swaybar. Scarebird Model VAL, with a barely used Raybestos disc brake master cylinder, barely used brake hoses, includes the center register spacers for the rotors, and instruction sheet. You would need to get the required Toyota Previa rotors (which must be drilled to fit) and Chevy Celebrity calipers, part numbers are on the instructions. Full disclosure: I got this kit second hand and I tried it on my 67 Dart and had trouble with the outboard brake pads on both calipers contacting the side of the rotor hat, so I've given up. I was using Raybestos rotors and NuGeon calipers. My loss your gain. Everything for $200.00 shipped to lower 48 United States from 43410.
