Has anybody copied a set or have the diamentions? This is for a 75 duster sb to B.B. Thanks. Kim
Welding required...you have to relocate the spool mount ears on the k-member.Isn’t the 75 spool mount? I think all you need are factory BBlock spool mounts from any car and it will go in with no problem. Oil pan is different of course.
Am I correct @RustyRatRod ?
Good to know...as I have been told different...that all you need are BB mounts from another Body class and it’ll drop right in!Welding required...you have to relocate the spool mount ears on the k-member.
