Schumaker vs TTI Headers
Big Block A body Tech
  1. 71Twister440
    71Twister440 Well-Known Member
    64
    16
    Dec 6, 2017
    Lagrangeville
    Local Time:
    10:21 PM
    I have seen and done some searching about TTI and Schumacher
    headers for the 440 into a Duster. My question is who has personal experience with these headers, fitment wise?, I notice it seems the Schumachers will fit better because they are a smaller tube. My motor I would estimate makes 500ish HP, so I dont want to constrict the motor if necessary but I also would like the ability to get past my steering box, starter and torsion bars without having to smash up the header, which the someone who installed this motor for my father 17 years ago already did. I do know dented headers have little impact on HP as has bee proven on a few video dyno tests, but they look like shit and everything is very close to touching. Thanks in advance for any advice and pictures.
  2. 68dodge
    68dodge Well-Known Member
    1,421
    263
    Jan 23, 2008
    Armagh, Pa.
    Local Time:
    10:21 PM
    I installed my 440 using Schumacher motor mounts and shims. Installed Schumacher headers with manual steering. I had no problems at all. My motor made 500 HP on the Dyno. Car ran it fastest time of 11.35s. It will average in the 11.40s depending on the weather. Yes the TTIs would make more HP, how much is the question.
    • Like Like x 9
    • jas0162
      jas0162 Well-Known Member
      490
      307
      Apr 23, 2014
      kansas
      Local Time:
      9:21 PM
      Nice car
    • marksmopar1
      marksmopar1 Well-Known Member
      663
      144
      Feb 21, 2014
      Winnipeg, Canada
      Local Time:
      9:21 PM
      Question, The shims, are they needed for the TRI-Y install on the 440?
    • rklein383
      rklein383 Well-Known Member
      1,460
      376
      Dec 2, 2005
      Local Time:
      9:21 PM
      I didn't use shims on my 440 69 Barracuda install with stock big block mounts and insulators. Not sure what other people have done.
      • Like Like x 1
      • Fisher
        Fisher Old Guy with a Cool car.
        1,881
        834
        Jul 22, 2012
        Regina Sask Canada
        Local Time:
        9:21 PM
        I have 1-3/4 TTI headers on my 426 low deck, made 525 hp and 552 tq. TTI doesnt make a 1-7/8 primary tube A body B motor header. They fit well , i can get all the spark plugs from the top except for #6 has to be had from the bottom.
        • Like Like x 3
        • 68dodge
          1,421
          263
          Jan 23, 2008
          Armagh, Pa.
          Local Time:
          10:21 PM
          I used them for more clearance for the oil pump and filter. The Schumacher mounts could move from the torque down at the track, just like any other rubber mounts. Also install a Schumacher torque strap. I did not want solid motor mounts. Have never had an issue with this set up.
          • Like Like x 1
          • halifaxhops
            halifaxhops It's going to get stupid around here! FABO Gold Member
            57,217
            25168
            Jan 20, 2014
            CENTRURAL, PA
            Local Time:
            8:06 AM
            I have Schumacher in my 440 dart with their mounts so far so good cleared the power steering box.
            • Like Like x 2
            • Darter6
              Darter6 Well-Known Member
              4,041
              1286
              Jan 16, 2008
              Nevada
              Local Time:
              7:21 PM
              If you want the ultimate for power,yes the TTI's. The ultimate ease of installation Schumacher tri-y's.I have run Schumacher's on a 451 Stroker B body(ran 11.90's street trim) and a 500'' B body(street driven only) The TTI's 440 drag only Duster. For a car mostly used on the street the tri-y's can't be beat.I really like them and they make good power. My next is a 361 B in a 63 Fury and will be using the Schumacher's.
              • Like Like x 2
              • 71Twister440
                64
                16
                Dec 6, 2017
                Lagrangeville
                Local Time:
                10:21 PM
              • 71Twister440
                64
                16
                Dec 6, 2017
                Lagrangeville
                Local Time:
                10:21 PM
                Exactly why I love this forum, you guys are great thank you for the help...............68 dodge is that the factory manual steering box?
              • space duster 383
                space duster 383 captjim
                31
                8
                Dec 5, 2017
                Norfork, AR
                Local Time:
                9:21 PM
                I have had a set of chromed headers on order from Schumacher since Dec 22. They are for my'73 Duster 383. Back order is expected end of April. (Were expected end of Feb) They won't tell me what the problem is, but it is at the manufacturer. Worth the wait, I guess. Chose them because of installation without any modification. Question I have is ....Will I need to get different motor mounts? Should I get the parts that mate to the headers and will swivel to any direction to mate with the exhaust pipes?
              • 68dodge
                1,421
                263
                Jan 23, 2008
                Armagh, Pa.
                Local Time:
                10:21 PM
                yes it is the a factory manual steering box.
              • Darter6
                4,041
                1286
                Jan 16, 2008
                Nevada
                Local Time:
                7:21 PM
                Space duster, It may be who makes them for Schumacher. I know that headers made for Clifford the 6 cylinder people,a minimum of 25 sets have to be on order for them to tool up and make a run.
                Check with Mike at Schumacher if they come with the flanges to make head pipes. I believe they do. One set I made, the other was from the muffler shop
              • space duster 383
                31
                8
                Dec 5, 2017
                Norfork, AR
                Local Time:
                9:21 PM
                I did check with Mike. Nice guy. Offered refund and couldn't do anything to speed it up. I didn't think about the bender needing a descent lot to tool up. This is somewhat of a specialty. My biggest problem is I need to pull the trans and it would make it convenient if I could put the headers on at the same time while the motor is loose. I'm not POd at Schumcher, but, if your looking for 383s on a Duster, ask the right questions before ordering.
                • Thanks! Thanks! x 1
                • 383Duster
                  383Duster Well-Known Member
                  1,807
                  436
                  Jan 11, 2009
                  Dallas, TX.
                  Local Time:
                  9:21 PM
                  I have the Schumacher's on my 383, tons of room. I changed all eight plugs from the top in 30 minutes just a couple weeks ago. FYI...TTI makes shorty headers also..
                • roccodart440
                  roccodart440 Well-Known Member
                  5,527
                  4537
                  Apr 19, 2010
                  Local Time:
                  10:21 PM
                  I've run both on my 440 dart. The power difference is noticeable but more so on a timeslip than seat of the pants. For the money spent and fitment I'd always go TTI from now on.
                • 68dodge
                  1,421
                  263
                  Jan 23, 2008
                  Armagh, Pa.
                  Local Time:
                  10:21 PM
                  What was the time slip difference and was the weather the same when you ran each time?
                • roccodart440
                  5,527
                  4537
                  Apr 19, 2010
                  Local Time:
                  10:21 PM
                  My car only changes hundreths with the weather. The weather was similar though. I saw about .4 average difference in ET which is very similar to the testing that you can find on TTI vs. Schumacher headers.
                • 68dodge
                  1,421
                  263
                  Jan 23, 2008
                  Armagh, Pa.
                  Local Time:
                  10:21 PM
                  What size tubes and collector on the TTI's.
                • space duster 383
                  31
                  8
                  Dec 5, 2017
                  Norfork, AR
                  Local Time:
                  9:21 PM
                  Has anyone put TTIs on a 73 Duster 383 with Edelbrock Al heads? Does the engine or auto trans need to be dropped? All the way or partial? Would different eng mounts help?
                • roccodart440
                  5,527
                  4537
                  Apr 19, 2010
                  Local Time:
                  10:21 PM
                  440-200 headers. 2" primary, 3.5 collectors. Exhaust is TTI 3" front to back with an H pipe and Borla XR-1 SS mufflers. It goes right to the bumpers with double rolled slash cut tips. The factory tips are restrictive and also change the sound do to their size and design.
                • roccodart440
                  5,527
                  4537
                  Apr 19, 2010
                  Local Time:
                  10:21 PM
                  Which Edelbrock heads?
                  Some of their headers will only work with raised port heads if you have a low deck block. (i.e. victor eddy heads)
                  These headers (http://www.ttiexhaust.com/MoparClassics-Headers/400SR-218/TTi400SR-218.htm) will work with standard port heads like the Eddy EZ street, performer and performer RPm)
                • 68dodge
                  1,421
                  263
                  Jan 23, 2008
                  Armagh, Pa.
                  Local Time:
                  10:21 PM
                  Thanks for the info, not worth change to me from the Schumacher headers to the 2" TTI's for only .4 of difference compared to what my car runs now. Plus I like the room around the motor.
                • roccodart440
                  5,527
                  4537
                  Apr 19, 2010
                  Local Time:
                  10:21 PM
                  The main reason I switched is I needed a new set of headers anyhow as mine had been repaired a few times. I also needed a new exhaust. So my best bet was to go all TTI.
