Season 13, episode 7 of "Name these Parts"
Early A-Body Discussions
  1. ZooKypr
    ZooKypr Well-Known Member
    1,830
    170
    Jul 5, 2009
    NJ
    Local Time:
    4:25 PM
    Looking to post these parts up for sale if I can ID them properly. I acquired them a couple years ago and they were mixed in with some 64 Barracuda and 67 to 69 Camaro parts.
    Please reference the number next to the part and its application when you reply. Thanks!
  2. 69moredoor
    69moredoor Well-Known Member
    178
    132
    May 5, 2019
    VA
    Local Time:
    4:25 PM
    Number one looks like a throttle linkage bracket the bolts to rear of a block. My l/f heads had ones just like it
    • Like Like x 1
    • Agree Agree x 1
    • RAT ROD AL
      RAT ROD AL I know just enough to be dangerous FABO Gold Member
      4,147
      4683
      Jan 18, 2013
      St. James City. FL.
      Local Time:
      4:25 PM
      67-69 Camaro? Or is that a type O
    • Cudabnu
      Cudabnu 64 Valiant vert, 318/727
      354
      398
      Mar 4, 2019
      Moorpark, CA
      Local Time:
      1:25 PM
      1,2,3,4 and 6 look to all be the kick down linkage for an early 273 ( I may be interested depending on price!)
      1 bolts to the back of the head
      2 bolts to the transmission kickdown to the swivel on the side of the trans.
      3 goes from #1 to the swivel on the trans
      4 goes from the carb to #1
      (4 and 6 are the same part)
      #8 is a LEFT door striker plate
      • Like Like x 2
      • Agree Agree x 2
      • ZooKypr
        1,830
        170
        Jul 5, 2009
        NJ
        Local Time:
        4:25 PM
        Yes, 67-9 Camaro...had to buy all or none, so the Chevy parts came back home with me.
      • RAT ROD AL
        4,147
        4683
        Jan 18, 2013
        St. James City. FL.
        Local Time:
        4:25 PM
        Seems like I've seen #10. Bracket that holds the A/C condenser ( or what ever the bottle with the little bubble glass on it). On mopars.
        • Like Like x 1
        • Agree Agree x 1
        • ZooKypr
          1,830
          170
          Jul 5, 2009
          NJ
          Local Time:
          4:25 PM
          Thanks..I thought it had to be trans related but didn't want to assume. The previous owner wanted to do a 273 conversion on his Barracuda but gave up on the project.
        • 69FBCuda
          69FBCuda Life in the Fast Lane FABO Gold Member
          2,821
          1485
          Aug 28, 2014
          Florida
          Local Time:
          4:25 PM
          #1 is for a 2 barrel
          • Like Like x 1
          • Cudabnu
            354
            398
            Mar 4, 2019
            Moorpark, CA
            Local Time:
            1:25 PM
            What is the difference between the 2 and 4bbl, arm length?
          • George Jets
            George Jets 1967 Dart 2 Door FABO Gold Member
            3,269
            4805
            Jan 18, 2019
            Farmington MN
            Local Time:
            3:25 PM
            #10 is the Strap that holds the screw up Jack for raising up the vehicle to change spare tire.
            72 to 78 D series Pickups. Mounts on core support under the passenger side head light at the inner fender to core support.
            • Like Like x 2
            • pishta
              pishta I know I'm right....
              18,584
              8055
              Oct 13, 2004
              Tustin, CA
              Local Time:
              1:25 PM
              8 looks like a flywheel/convertor bolt on stop for removing the damper or something. Dont know why it would have teeth if nothing else, maybe a little big? Or maybe a jack part.
            • BillGrissom
              BillGrissom Well-Known Member
              7,394
              411
              May 10, 2009
              Sacramento
              Local Time:
              1:25 PM
              As mentioned, #1 is transmission kickdown linkage for small-block V-8, at least same as in my 1965 Dart 2 bbl. Bolts to aft side of driver's cylinder head. 2-4 look like linkages for it. #8 might be a strap for a radiator overflow bottle, at least ones on later Mopars looked similar. My 1965 Dart had an aftermarket bottle and mount. #5 is a mystery, something which spins slowly.
              • Thanks! Thanks! x 1
              • cudamark
                cudamark FABO Gold Member FABO Gold Member
                7,391
                576
                Mar 14, 2009
                San Diego
                Local Time:
                1:25 PM
                #'s 1,2,3,4, &6 are kickdown linkage. I'd need a better photo of the upper bell crank arm on #1 to tell if it's a 2 bbl or '65 4bbl. It's not a '66 4bbl one however. Same with the other linkage parts....need a better close up photo with measurements. #7 looks like a '63-4 Jiffy Jet bag bracket. #8 is a RH door latch striker for a '64-6 model. #10 looks like a rear muffler hanger bracket, or, maybe an A/C dryer bracket.
                • ZooKypr
                  1,830
                  170
                  Jul 5, 2009
                  NJ
                  Local Time:
                  4:25 PM
                  Thanks for the input fellas!
