I recently converted to a serpentine (8 groove) setup by CVFRacing on my 440 w/AC and PS. One belt goes from the crank pulley to the alternator and the other goes around everything else. I found a pulley misalignment in the PS pump mounting so fixed that. I am using a shroud & 6 blade Deraile mechanical fan without clutch to ensure maximum low speed cooling. When I bought the radiator (ECP) I got their dual electric fan setup but I can't use it because of insufficient clearance between the fans and the serpentine pulleys. Problem is when the engine really starts to pull around 4000 RPM I hear the dreaded screech. The belts are tight and the alignments look good now. Am at a loss why it still screeches. Edit: now wondering if the mech fan is putting too much load on the belt causing the problem?
