If it's a Texas car, it should be fine. Check around the mounts for the upper control arms and where all that welds to the frame rails. Check the frame rails to make sure they are solid. The part where the top shock mount is only holds the shock itself, unlike a Rustang where it holds the weight of the front of the car.
