Should I keep my power steering
Suspension, Steering and Chassis
  1. doopdoop67
    doopdoop67 Well-Known Member
    190
    50
    Sep 8, 2015
    pacifica california
    Local Time:
    11:26 PM
    Hey guys I’m getting ready to do a bunch of work on my 67 dart. I have all the drivetrain from a 72 dart so it has the power steering from a 72 318 car. I am considering throwing a manual gear in the car because the power steering sucks. Has anyone done this and recommend doing it? I know I need an adapter or a manual steering column like this one https://www.jegs.com/i/Mopar+Perfor...tA0wTA7SmVz5cGQU-uSMp5LlRoYCCDVAaAtk6EALw_wcB
  2. SLOPAR72
    SLOPAR72 Well-Known Member
    1,843
    1204
    Jan 5, 2016
    Richmond, VA.
    Local Time:
    2:26 AM
    Only you can answer that honestly. Ask 10 people and get 10 different answers.
    What's so wrong with the setup currently?
    JW
    • Like Like x 2
    • Agree Agree x 1
    • doopdoop67
      190
      50
      Sep 8, 2015
      pacifica california
      Local Time:
      11:26 PM
      It feels to loose for me. I don’t like the power steering pump bracket seems very flimsy to me. I like firm steering and the mopar power steering doesn’t feel right to me. Maybe I’m doing something wrong though
    • ChuckDock
      ChuckDock FABO Gold Member FABO Gold Member
      284
      95
      Jan 7, 2018
      Goodrich, MI
      Local Time:
      2:26 AM
      My 67 cuda had power steering when I bought it. It leaked really bad so I had to decide to fix that or go to manual steering. There are pro's and con's to both for sure. I do like how the car drives better now with the manual box, more road feel, but the stop and turn/slow moving steering is a bear after a while. I also like the small foot print the manual box is inside the engine bay. I'm swapping my 273 for a 340 now and the 340 will have headers so the smaller steering box should help with fitment. If you plan on driving it a lot then its really something to think about. If it's seldom then manual isn't to bad overall. I think my box is a 16 to 1 ratio.
      • Like Like x 1
      • ChuckDock
        284
        95
        Jan 7, 2018
        Goodrich, MI
        Local Time:
        2:26 AM
        That was the other reason for me to go to manual, the power steering felt over powered and just kind of loose because of that I think. Other folks have mentioned the over powered, powering steering and there are fixes for that somewhere on this forum if you go that route.
      • 66jim
        66jim Well-Known Member
        448
        410
        Dec 11, 2007
        NE PA ie pennsyltucky
        Local Time:
        2:26 AM
        First determine if something is wrong or worn or loose on all steering related parts. If your car has a saginaw PS pump, it can be shimmed to reduce pressure.
        • Like Like x 1
        • Agree Agree x 1
        • Mike69cuda
          Mike69cuda 64 is the new 17 FABO Gold Member
          1,208
          929
          Jan 2, 2018
          Overland Park Kansas
          Local Time:
          1:26 AM
          Mine drove a little wild when I got it, figured out the bolts that hold the power steering box to the frame were loose.
          • Like Like x 1
          • AJ/FormS
            AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
            17,591
            5988
            Jan 19, 2014
            South-Central Manitoba,Canada, 900ftelevation
            Local Time:
            1:26 AM
            The power steering box can be modded several ways and end up feeling similar to a manual box, but with faster steering.
            If the box is in good shape,then the looseness or vagueness is not coming from the box. The looseness you feel with the engine turned off, is the way it works, but you can change that. In any case most of it goes away after the engine is running. Some of it has to be there to operate the valve. If you set it up too tight, you will be chasing the car all over the road.
            I agree they are from the factory, over-boosted; this is easy to fix.
            But, you'll have to swap the Federal pump out, in favor of a Saginaw. The Federal cannot keep up in fast left/ right maneuvers or when doing figure-8 donuts.
            I installed a 13" steering wheel, with a big fat foam rim, and now I'm happy.
            Brakes are also over-boosted.... which too is fixable.
          • doopdoop67
            190
            50
            Sep 8, 2015
            pacifica california
            Local Time:
            11:26 PM
            I have a Chrysler pump. I know thag my gear or worn out which is why I’m considering just switching over to manual. Is the Chrysler pump bracket capable of holding a Saginaw pump?
          • doopdoop67
            190
            50
            Sep 8, 2015
            pacifica california
            Local Time:
            11:26 PM
            I had a really bad leak from the pump so I replaced the pump and the only pump I could find leaked too (crappy Chinese rebuild) so orileys found me another pump and this ones is super noisy. I think mopar a engineers missed on the power steering system I have lol. Sometimes I think a simple manual gear would be better
          • ChuckDock
            284
            95
            Jan 7, 2018
            Goodrich, MI
            Local Time:
            2:26 AM
            There is a lot to be said for the simplicity of manual brakes and steering. Car stalls, no biggy, it drives the same. No belts, pumps or power steering fluid level to worry about. The 340 I'm putting in won't make a lot of vacuum at idle and that's no issue since I have manual brakes. Just less to brake so more dependable to some degree.
            But are their times I'd like power steering still..for sure.
            • Like Like x 1
            • Dana67Dart
              Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
              3,597
              2142
              Jul 16, 2017
              Northern Colorado
              Local Time:
              12:26 AM
              67 dart with stock manual steering. I
              have no issues. I can palm steer most of the time, parking is a hand over hand operation but no big deal.
            • doopdoop67
              190
              50
              Sep 8, 2015
              pacifica california
              Local Time:
              11:26 PM
              I run manual discs up front and have zero complaints. Stops good and the pedal isn’t hard compared to the 65 el Camino me and my dad have that has vacuum brakes
              • Agree Agree x 1
              • 383Scampman
                383Scampman Well-Known Member
                1,555
                786
                Nov 24, 2013
                New Hampshire
                Local Time:
                2:26 AM
                I switched from power to manuel . On the road it's no different . Parking is but not too bad and i'm 75 years old
                • Like Like x 3
                • doopdoop67
                  190
                  50
                  Sep 8, 2015
                  pacifica california
                  Local Time:
                  11:26 PM
                  Hopefully I can find the strength in my millennial self to turn the wheel lol!
                  • Like Like x 1
                  • moparmandan
                    moparmandan FABO Gold Member FABO Gold Member
                    2,136
                    1981
                    Jun 28, 2017
                    Central FL
                    Local Time:
                    2:26 AM
                    Dump the ps. I like manual. Got manual brakes also.
                    • Like Like x 2
                    • Agree Agree x 1
                    • Mike69cuda
                      1,208
                      929
                      Jan 2, 2018
                      Local Time:
                      1:26 AM
                      I’m a softie, mine has ps, pb, ac & cruise control. Wouldn’t have it any other way.
                      • Like Like x 3
                      • Agree Agree x 1
                      • RustyRatRod
                        RustyRatRod Weenie idiot loser. FABO Gold Member
                        58,597
                        29078
                        Jun 7, 2010
                        Georgia
                        Local Time:
                        2:26 AM
                        I've never seen the point to power steering on cars as small and light as A bodies.
                        • Like Like x 1
                        • moparmandan
                          2,136
                          1981
                          Jun 28, 2017
                          Central FL
                          Local Time:
                          2:26 AM
                          That's what makes the world go round!
                          • Like Like x 1
                          • moparmandan
                            2,136
                            1981
                            Jun 28, 2017
                            Central FL
                            Local Time:
                            2:26 AM
                            Me too. But I learned to drive on a 8N Ford.........
                          • George Jets
                            George Jets 1967 Dart 2 Door FABO Gold Member
                            1,891
                            2661
                            Jan 18, 2019
                            Farmington MN
                            Local Time:
                            1:26 AM
                            Should be able to find those adapters for power steering column going to manual box for about 130.00 on ebay.
                            They work great.
                          • George Jets
                            1,891
                            2661
                            Jan 18, 2019
                            Farmington MN
                            Local Time:
                            1:26 AM
                            The biggest thing with manual steering is to at least have the car slightly moving as you are turning the wheel, then they are great.
                            Dead Stopped steering wheel turning, not so much . . .
                            • Agree Agree x 3
                            • Like Like x 1
                            • RustyRatRod
                              58,597
                              29078
                              Jun 7, 2010
                              Georgia
                              Local Time:
                              2:26 AM
                              I have a 49 8N and I can steer it with one finger.
                              • Like Like x 2
                              • moparmandan
                                2,136
                                1981
                                Jun 28, 2017
                                Central FL
                                Local Time:
                                2:26 AM
                                Oh cool! I was a little kid, took all I had to turn it in the soft Florida sand. LOL.
                                About 1976 we got a Ford 3600 with power steering. S*** in in high cotton then.
                                • Like Like x 1
                                • George Jets
                                  1,891
                                  2661
                                  Jan 18, 2019
                                  Farmington MN
                                  Local Time:
                                  1:26 AM
                                  No power steering ? One less thing leaking oil all over your garage floor. Nice clean look of the engine too without them.
                                  A simple V8 sitting in the engine bay look so cool when there are no added accessories on it.
                                  A little more power to the ground at the rear wheels too.
                                  • Like Like x 2
                                  • Agree Agree x 2
