show me your early A!
Helle to all Early Abody lovers. I have only been a member for a short time but this site has been filled with great info and very helpful members. I thought I'd post a couple of pics of my 66 Dart GT. I hope everyone enjoys the long weekend.
I've got it on 4 tires that hold air! The floor needs a "little" work. However I can start it reaching through the window even after a week! It's running in the pictures, almost no smoke! Tags were 22 years out of date when I bought it
glad your saving that valiant/lancer,,we need more of those kool A bodies,,,,i see if has flintstone brakes,,,but it has a clutch pedal and linkage,,,most important,,lol
My '65 "S" 340 About 10 years ago. Then in went a 451 B and now it has a turbocharged 225.
Damn! So YOUR the one that can help me decide on the engine for my wagon... You've had it all!
I like the style also! I plan on doing what I can to get the best mpg I can with it. Eventually, a833OD, HEI, fuel injection, gear ratio, tire size. For now just can't get the throwout bearing to move, going to pull cover off and see if I can do anything with it. any suggestions? I cant afford a new one if I can get this one to work. I also don't have a place to pull the engine. Step on pedal, bearing doesn't move,Linkage is free. No sounds from it when engine is running.
Word...started life as a 273/4, got a rod knock so in went a 318. 318 oil pump failed so in went a +.040 340, sold that and got a std 340. Sold that and was given a 451 to babysit for 7 years. It had to go back to the owner so he gave me a 318. Bought a cheap drop in 360 then found some cheap stroker pistons so I started to build a 403. In the meantime, the 318 got traded for a 225. Bought a pair of tiny T25 turbos on a whim and sold them for a CT26 Celica 3.0 turbo. Got the itch to build a six so thats where I am now. I should put zippers on my K member.......Wagon motor? Any of them! But the Early A is probably the worst V8 platform to stuff motors in.
I picked it up in Cloudcroft NM.drove it to St Louis. Someone put "s" emblems on it, but its just a 4spd commando car. When i get on it with my little boys in the car they yell " thats the way you race the barracuda dad". Cuda fans in the making!
65 Valiant V200. Original body, with the exception of one changed fender. Original 273 2bbl, auto. 273 has been freshened up with new rings, seals, etc. Daily driver.
She looks rough, but she's rust free, and runs like a charm.
im a little confused,,,when you step on the pedal,,does the fork move??? and not the throw out bearing or what ?
staying on top of some new mods in preparation for the 315 doge hemi engine swap. New hood paint and hemi scoop. installed bumper with (faux) gasser tank.
Here is my 65 that I picked up about a month ago. It's a non Formula S Commando 273 auto console shift. Can't wait to start on it once the dart is finished.
I bought this 65 Cuda Commando from a guy in the mountains of New Mexico. Its a 4spd with a few nice options. Its painted a Ford color! When the owner got it back from the paint shop it was the wrong color, since the guy did such a nice job, he let it slide. Doing a few upgrades and wanted to install spitfire headers, but since Harold dosent make em anymore, ill have to save up for a set of Dougs headers.
Curious on how you mounted that tank?
Rangoon red....ewwww!:wack:
When I bought the cuda it didn't have the front pumper mounted. I knew I wanted the bumper on eventually and built aluminum brackets where the front plate goes to mount the "gasser" tank. Didn't know whether I'd like it or not......but I think it goes with the look of the car. I had to drill two holes in the top part of the bumper to mount turn-buckles for the straps, but other than that I used the existing liscense plate holes. thanks.........
