Side Window Glass Removal
bob7four
New Jersey
Can just the glass be removed instead of the entire regulator assembly on a 69 Barracuda?
Door glass comes out with the vent assembly, the regulator needs to be separated first.
Alan
Not certain on a Barracuda, but I was able to do it on a 70 Duster. Had to separate the glass from regulator, then mounting inserts off the glass in order to be able to get the glass past the sweeps. Plastic part of the mounting inserts is brittle so had to replace one. Other thing is working in there is a bear, with a lot of rolling up and down to manage access to achieve it. Good luck.
p.s., based on Cuda Al’s post, I don’t think things are similar enough to achieve like I did on the Duster.
