1. demon 340
    demon 340 Active Member
    44
    2
    Apr 10, 2007
    Local Time:
    4:11 AM
    Is there a difference in a original ta or aar 6 pac compared to a after market edelbrock. I was told one has chrys part number other does not. if so is original worth more?
  2. Dartnut
    Dartnut Don't hate me because i'm beautiful
    11,752
    4814
    Apr 19, 2007
    Southern Alberta
    Local Time:
    3:11 AM
    The answer is yes to all of your questions.
  3. rklein383
    rklein383 Well-Known Member
    1,713
    695
    Dec 2, 2005
    Local Time:
    4:11 AM
    Sometimes after market six packs have mechanical linkages for the outboard carbs. An original six packs have vacuum diaphragms to open up the outboard carbs.
  4. EL5DEMON340
    EL5DEMON340 Well-Known Member
    4,068
    179
    Feb 6, 2009
    Aurora,IL
    Local Time:
    5:11 AM
    As far as I know edelbrock doesn't make the intake, mopar performance is casting them from edelbrock design. They say mopar on them and are a bit heavy compared to the originals. Originals are around $350 to $450 the mopar ones are $250ish. Performace is about the same. I think all the original t/a aar ones had the part number but back then you could get a over the counter edelbrock from a speed shop without the number.
  5. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    51,498
    20462
    Oct 14, 2010
    Idaho
    Local Time:
    2:11 AM
    Actually, Ed DID make the 69 1/2 440 6bbl intakes, I don't know the history of the T/A / AAR smallblocks
  6. 70aarcuda
    70aarcuda Master Hoader of SBM FABO Gold Member
    16,559
    5357
    Jan 16, 2005
    las vegas
    Local Time:
    2:11 AM
    Mopar Performance cast something? please..LOL
    Outside vendors cast the intakes whether they are edelbrock or weiand...
  7. EL5DEMON340
    4,068
    179
    Feb 6, 2009
    Aurora,IL
    Local Time:
    5:11 AM
    Actually Buddy bar casts the mopar one. Eddy I believe cast some originals and also farmed out a lot to Buddy Bar, the original BB 6 packs were eddy and when they could not keep up Chrysler cast then from cast iron. But I don't think the OP needed that much info
