[WANTED] Slant 6 Distributor Hold Down
RustyRatRod
Caput villa stultus
Georgia
I am looking for the late model slant 6 distributor hold down and also the small ring that bolts to the bottom of the distributor. This is not the 2 way adjusting hold down, it is more of a conventional clamp similar to a small block and has the ring that bolts to the bottom of the distributor as well. Two pieces. It was factory on the later model slant 6s. Looks like the picture below. Thank you.
Rob I have a few of the upper part that mounts on the distrib, the lower is almost the same as a LA just needs a bit of tweaking.
Hey Rusty if you need one I can pull the whole assembly off a 1976 slant six duster I just got. just pay shipping
