slant 6 oil weight
I guess my question is that, will 10-30 be good enough to lubricate a bit stiffer valve springs crane springs similiar to the mopar red 340 springs. Also cam is the loved and hated 292 mopar purple grind. I live in San Antonio,Texas where it gets toasty in summer and winter is mild. Or 10-40 could be a better choice? My driving is for the most part "normal" with spirited jaunts here and there. My engine/bearing clearances are factory. Oil pump is stock pressure/flow. Windage tray and oil slinger are only things I added.
I've upgraded to a high-lift, short-duration in my slant six and have been using 340 valve springs since 1987. I've always run 10W-30 except for the time I tried 15W-40. Any modern CK-4 heavy duty oil with the Ford WSS-M2C171-F1 approval should have enough ZDDP to protect your valve train. I would stay away from racing oils because they have less detergents than HDEOs, which means you'll need to change your oil a lot more often to minimize sludge formation.
Unless your oil runs really hot, you'll get more flow to your bearings with a thinner oil (like 10W-30) than a thicker oil like (10W-40). Chrysler spec'ed 20W-40 oils for summer operation so I would go with a 15W-40 if your low temperatures rarely fall below +32°F. See Chrysler Oil Recommendations and Engine Wear.
3 pages of charts graphs and hogwash. Almost as bad as the crankcase breather/pcv valve thread.
From a 1976 Chrysler FSM---10w30 to 20w50 is recommended when the temperature is above 32F. ---- Straight 30 weight is also included.
Why not add my two cents so I can beat that horse a little more. Here at Crower we have tested so many oils I cant even keep track of it all anymore. But here are the top four that we have tested. Driven, Brad Penn, VR-1 and last but not least is Rotella T-4 & T-6 50-50 blend. I get asked all the time what do I use in my daily driver slant six and I use the 50-50 blend Rotella. I drive my car 50 miles a day on the freeway at 2,500 rpm and just changed to a 200 4r trans and that dropped it too 2,000rpm. I just pulled the engine to do a 30,000 mile inspection. Also to do some work with Fast Fish for a billet rear main seal housing to use with their one cut rear main seal. Horse has fully been beaten now. Ha ha ha ha ha
Why are you mixing Rotella T-4 & T-6 into a 50-50 blend? And are you mixing the same grade?
I just can't understand why the need for designer oils in a slant six. Every slant six engine I have ever had, since 1974, whether stock or modified, got Parts store "house brand" 10w-30, and I have never had a oil related failure. Damm it ain't the space shuttle, and Unckel Sam ain't paying for it.
As with all motors
I can't believe i read all the threads.
My worthless opinion= all /6's require oil to run. Sometimes Not!
i guess vegetable oil Hasn't been tried!
We have some old machines at work. I try to figure out what oil they are supposed to have. But sometimes it comes to ‘any oil is better than no oil’ to keep them running.
