Slant 6 swap 170 to 225
Slant 6 Engines
  1. CommieHook
    CommieHook Member
    14
    0
    Jan 27, 2013
    Hot Springs, AR
    Local Time:
    11:30 PM
    Hey guys, I imagine that this has been asked before, but I thought I would give it a try.
    The 170 in my '65 Valiant has crapped out (cylinder head) and I have a 225 in a trash '74 Duster. The 170 is mated to a 3 on the tree while the 225 has an automatic. I'm just wanting to swap the engines, not the trannies. What if any problems will I run into?
    Thanks!
  2. RustyRatRod
    RustyRatRod Weenie idiot loser. FABO Gold Member
    57,874
    27878
    Jun 7, 2010
    Georgia
    Local Time:
    12:30 AM
    The crankshaft register is a different size on the later 225. I think that means you will need a flywheel for the 225.
    • Agree Agree x 1
    • slantsixdan
      slantsixdan =..=
      6,410
      1520
      Jan 7, 2007
      Vancouver BC
      Local Time:
      9:30 PM
      You'll need to swap the oil pan and pickup tube off the '65 motor onto the '74 motor, and make a spacer to space the exhaust headpipe down an inch or it'll want to hit the floorpan under acceleration (or, better, make a new 2-1/4" headpipe).
      • Like Like x 2
      • valiantwagonguy
        valiantwagonguy FABO Gold Member FABO Gold Member
        830
        533
        Oct 20, 2005
        Long Island
        Local Time:
        12:30 AM
        The oil pan needs to come from a n early A and the flywheel needs to come from a 67 or later slant . Use the 170 motor mount brackets and mounts and use the earlier ( 64-66 carb ) so the linkage from the gas pedal will work. I'd use the 170 distributor too unless you want to fool around adapting the electronic one to your car. .Other than that it's all the same
        • Like Like x 2
        • Slantsix64
          Slantsix64 Well-Known Member
          2,110
          770
          May 11, 2014
          SGV
          Local Time:
          11:30 PM
          Flywheel needs to be from 68 and up, also your exhaust 170 head pipe will be short to connect on the 225. Also you might need to add a pilot bearing in the auto 225 you might or might not depends, i would run the later magnum pilot bearings easy install and over the counter part, good luck!
        • Wyrmrider
          Wyrmrider Well-Known Member
          2,457
          1165
          Sep 5, 2016
          los angeles
          Local Time:
          9:30 PM
          see u in march
          jim
          good move
        • 65 Cuda 340
          65 Cuda 340 Active Member
          28
          33
          Dec 27, 2019
          Tallahassee Florida
          Local Time:
          12:30 AM
          The slant six crank flange was enlarged 1/4 inch beginning with the 1968 model year. So your 65 flywheel won't bolt up to a 74 crank as is. However, you don't have to change flywheels. Just take your 65 flywheel to a machine shop and have the center hole enlarged to fit the post-67 225 crank. Will work fine. The pilot bushing is a different issue; most automatic transmission cranks - V8 or six - are not fully machined for a pilot bushing. You might luck out and have an automatic-transmission 225 that has a fully machined pilot hole. If not, NAPA used to offer a conversion bushing that would fit in the semi-finished pilot hole in the crank, but I think they are NLA. Not a problem these days, as the readily-available pilot roller bearing that came on manual trans Dakotas and probably others will fit just fine and will work better than the conversion bushing anyway.
