1. Chrono
    Chrono Well-Known Member
    61
    28
    Jan 3, 2015
    Bloomsburg, PA
    Local Time:
    12:37 PM
    Hey guys, been awhile. I've still got the Duster, and I'm looking at (finally) starting the restomod process by the end of the year.
    I'm still hung up on transmission options. I'm interested in getting an AX15 behind the Slant. Has anyone done this? Who makes an adapter for this if they have?
    Any help is always appreciated!
  2. DionR
    DionR Well-Known Member
    2,022
    233
    May 7, 2008
    Spokane, WA
    Local Time:
    9:37 AM
    Can’t remember anyone completing an AX15 swap, only T5’s.
    But I started adapting an R154 to a slant and they have the same mounting face. Still have the adapter and bellhousing, but the project ended up being too rusty and went away.
    If you wanted, I could try and dig up some pictures later.
    And I have no plans for the parts I still have...
  3. Slowswinger
    Slowswinger Well-Known Member
    590
    726
    Jul 9, 2014
    Montana
    Local Time:
    10:37 AM
    • Like Like x 1
    • Chrono
      61
      28
      Jan 3, 2015
      Bloomsburg, PA
      Local Time:
      12:37 PM
      I'd love to see some pictures
    • DionR
      2,022
      233
      May 7, 2008
      Spokane, WA
      Local Time:
      9:37 AM
      Probably going to be later tonight but will post what I have.
      • Like Like x 1
      • DionR
        2,022
        233
        May 7, 2008
        Spokane, WA
        Local Time:
        9:37 AM
        I think I had Novak do the adapter plate, but not certain. It could have been the other place that does adapters like this (of which I can't remember their name right now). I had them leave it as a blank rather than shape the outside, I think because I didn't know where the bellhousing bolts would land. I had them put holes in to match a Mopar bearing retainer so I could center the bellhousing up on it. Ended up being a Hemi bearing adapter as it was the only one big enough to fit over the input shaft.
        Here is the adapter as I got it:
        Adapter 002.jpg Adapter 004.jpg Adapter 006.jpg Adapter 007.jpg Adapter 008.jpg
        Note that to make this work, I had to saw the tube off the R154 bearing retainer. Needed to keep the Toyota bearing retainer but the the Mopar bearing retainer wouldn't fit over the throw out bearing slide.
        I even went and bought a Stage 3 clutch from Spec to fit the slant 6 flywheel and match the input splines on the R154.
        Here is a picture of the input shaft and how far the pilot bushing adapter would have to reach:
        Note that the AX15 input shaft might be a different length. This is just for reference.
        • Like Like x 1
        • DionR
          2,022
          233
          May 7, 2008
          Spokane, WA
          Local Time:
          9:37 AM
          Here are pictures of the transmission and bellhousing:
          Adapter 011.jpg Adapter 012.jpg Adapter 013.jpg Adapter 014.jpg Adapter 017.jpg Adapter 018.jpg
          As I recall, the adapter plate could have used some more shaping, but I got tired of messing with it and figured I would clean it up some more before finished the project. Looks better than I remember it, though.
          • Like Like x 1
          • DionR
            2,022
            233
            May 7, 2008
            Spokane, WA
            Local Time:
            9:37 AM
            Another option you might look into is grabbing a bellhousing and AX15 out of a Dakota and tracking down one of the 727 adapter plates for a slant 6. I think they used them in trucks.
            With that you should be able to bolt up the transmission to a slant 6, but not sure what other problems you would have.
            Biggest issue there is how super rare the adapter plates were.
            • Like Like x 1
            • Chrono
              61
              28
              Jan 3, 2015
              Bloomsburg, PA
              Local Time:
              12:37 PM
              Alright. You've given me quite a bit to think about.
              Aren't the R154 and AX15 the same transmission?
              AX15s are plentiful at my local U-Pull it
              Is that the 3 or 4 speed bell housing you used in those pictures?
            • DionR
              2,022
              233
              May 7, 2008
              Spokane, WA
              Local Time:
              9:37 AM
              R154 and AX15 are from the same family of transmissions and they both have the same bolt pattern for the bellhousing. Big difference between the two is gear ratios, the R154 is geared for a sports car (MK3 Supra Turbo) while the AX15 is for a truck. Pretty sure the input shaft is different between the two, and not sure about the shifter location.
              I know that someone on here has done an AX15 swap with a V8, might give you some useful info.
              I used a 4 speed bellhousing.
              • Like Like x 1
              • Chrono
                61
                28
                Jan 3, 2015
                Bloomsburg, PA
                Local Time:
                12:37 PM
                Considering the Slant 6 is a truck motor, it should be fine! Lmao
                But seriously, if I decide I don't like the gear ratio of the AX 15, I'll swap it to the R154
                So, are you interested in parting ways with that adapter?
              • AJ/FormS
                AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
                18,509
                6653
                Jan 19, 2014
                South-Central Manitoba,Canada, 900ftelevation
                Local Time:
                11:37 AM
                That AX-15 has very wide 1-2, and 2-3 splits, then a lil shorter fourth.
                I think you can get an NV3500 from a Jeep, or a GM truck, with a removable bellhouse. It might be easier to find a bellhouse for that, IDK. but the chevy inputs are a lot shorter. IDK if you can swap the Mopar guts into the Chevy case.
                The NV has very similar ratios to the AX-15, but the progression is a lil smoother. You will likely want to run 3.91s or so with the NV, compared to 3.55s with the -15.
                Here are the ratios I have recorded,there are others;
                AX-15
                3.83-2.33-1.44-1.00-.79od ......with 3.55s you get
                13.60-8.27-5.11-3.55-2.80, splits of
                .61-.62-.69-.79
                NV3500Dakota
                3.49-2.14-1.38-100-.73od ......with 3.91s you get
                13.65-8.37-5.40-3.91-2.85, splits of
                .61-.645-.725-.73 .....Here you can see the nicer progression, and shorter 4th
              • DionR
                2,022
                233
                May 7, 2008
                Spokane, WA
                Local Time:
                9:37 AM
                Wouldn’t be opposite to parting ways. Have absolutely no plans for it. Need to dig it out though, not sure where it is.
                You could look at the AR5 or MA5 for a cheaper alternative to the R154, too.
                • Like Like x 1
                • DionR
                  2,022
                  233
                  May 7, 2008
                  Spokane, WA
                  Local Time:
                  9:37 AM
                  NV3500 doesn’t have a removable bellhousing. At least not one I am aware of.
                • AJ/FormS
                  18,509
                  6653
                  Jan 19, 2014
                  Local Time:
                  11:37 AM
                  Right you are; the Jeep NV3550 has a separate BH
                • Chrono
                  61
                  28
                  Jan 3, 2015
                  Bloomsburg, PA
                  Local Time:
                  12:37 PM
                  I have plans to swap a 8.25 out of a Dakota/Durango with a factory LSD. It'll ditch the glassy 7.25 that's in the Duster.
                  And 3.55 was the rear gear I wanted too.
                  The 7.25 has a 2.74 in it
