Slantsix64
what kind of jets and metering rods are you running on your slant six 225 9.1 compression. I'm running stock jets and rods up front and just leaned out the secondary to .89 getting 18-19 mpg.
What was your compression ratio?I have messed the with 500avs for several years. The best combination of jets and rods was what Edelbrock installed from the factory. I did change the step up springs to match my idle vaccum. The biggest problem that I had, was that stock replacement fuel pumps couldn't keep the fuel bowls full at full throttle.
