slant six NO COMPRESSION
Slantsix64
Los Angeles
So i had my head redone and milled, along with putting a new camshaft and timing gears, i try to do the cam break process no start, motor sounds weak when cranking do a compression test and 0 compression WTF i torqued the head to 70 ft pounds new gasket lined up the timing gears etc any ideas?
Throttle plate needs to be wide open when testing compression, check the cam make sure its indexed correctly. If valve are out of sync you will hear air escaping out of the carb
