abodyjoe
@slantsixdan what's you opinion on these LED headlights? any good or garbage? H6024 Dual Beam Sealed Beam LED Headlight Conversion Kit
man those are so ugly. wish someone would make a good LED light that actually looks like it belongs in an older car.
already running relays with ge nighthawks and they are good. figured if i could go led id do it.If You're concerned more with aesthetics, find a quality sealed beam,.....good luck, You'll need it. Every sealed beam I've purchased over the last 10yrs or so has had a barely better than 50/50 chance of the epoxy failing. And the lens accuracy sucked on a number of them, looked like they were made in a backyard sandbox.
Yeah, I get it, the Grote unit looks as close to "normal/old school" as they come at present.already running relays with ge nighthawks and they are good. figured if i could go led id do it.
those are perfect for a GTO, since they almost resemble an eye of a goat lol.Those Pacifica fogs are pretty good. These little-known Subaru ones are even better, and they're even yellow, just like the Bible says fog lamps shalt be.
Are there any decent 7" H4 conversion lamps that aren't Chinese Trash?
You'd think someone could make a relatively stock appearing lens/reflector assembly with an LED light source.
Ive had good luck with a brand called auxitoAre there any decent 7" H4 conversion lamps that aren't Chinese Trash? I'm not feeling the LED love.
I'm also in the market for a set of near-laser focus lamps that will fit in a fog light hole, that will make **** a mile away burst into flame.
Not for lighting, just for turning on when these assholes refuse to shut off their high beams after I flash them. Fuckers need to spend some time in Ray Charles' shoes to learn their lesson.
