Slap it on or rebuild NOS carb?
Fuel and Air Systems
  1. dibbons
    dibbons Well-Known Member
    5,130
    3127
    Nov 6, 2009
    La Paz, B.C.S., Mexico
    Local Time:
    1:41 PM
    Found and purchased a 1973 Carter two-barrel NOS carb for my stock 1972 318. Can I just slap it on the motor, as is, and see how it works, or should I disassemble it and put in new gaskets and stuff from a rebuild kit first? (Looks like the carb has never been run before). Thanks for your opinions.
  2. Dartnut
    Dartnut Don't hate me because i'm beautiful
    11,737
    4775
    Apr 19, 2007
    Southern Alberta
    Local Time:
    2:41 PM
    I would disassemble it and verify the float level and cleanliness of it first and also check for dry gaskets or anything that doesn't look right.
    It may be new, but things happen after sitting a long time. Bugs and shelf wear etc. can do strange things.
    If all of that checks out, then i would flush out all of the passages with spray carb cleaner, install it and run/tune it.
    • Like Like x 1
    • AJ/FormS
      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
      21,740
      8977
      Jan 19, 2014
      South-Central Manitoba,Canada, 900ftelevation
      Local Time:
      3:41 PM
      ^^,what he said. Gaskets do shrink.
      • Like Like x 1
      • gtsdude
        gtsdude Well-Known Member
        835
        191
        Jan 10, 2010
        SE MN
        Local Time:
        3:41 PM
        As mentioned above, pull apart to make sure there is no junk in it, check float etc. My dad bought a NOS 2 barrel for his 383 Newport, it all checked out, put it on and been running for 5-6 years with no problems
        • Like Like x 1
        • 67Dart273
          67Dart273 FABO Gold Member FABO Gold Member
          51,436
          20389
          Oct 14, 2010
          Idaho
          Local Time:
          1:41 PM
          This is actually "new" or is this a rebuilt? I would bolt it on, if it's never been used. New gaskets are not the problem. A carb that has been used and then dried out is where gasket problems usually come up.
          Frankly, this is somewhat in the "what have you got to lose?" shelf
        • jimjimjimmy
          jimjimjimmy lobsterman FABO Gold Member
          4,706
          1558
          Nov 2, 2010
          p. e. i.
          Local Time:
          5:41 PM
          what will it hurt to run it 99.9% chance it will work perfect
        • 72Valiant4Door
          72Valiant4Door Trouble Maker
          980
          203
          Sep 20, 2015
          Chattanooga
          Local Time:
          4:41 PM
          I bought a reman'd carb that failed on me after less than 1000 miles...
          I would go through it.
        • slantsixdan
          slantsixdan =..=
          6,830
          2127
          Jan 7, 2007
          Vancouver BC
          Local Time:
          1:41 PM
          "Remanufactured" carbs are almost all garbage, no surprise it failed.
          New old stock carbs generally don't need rebuilding before use. It won't hurt (if you use a quality kit) but generally all you really need to do is grab a can of spray oil—any type is fine, Liquid Wrench or whatever—use an unbent paperclip to push the inlet needle's tip away from its seat hole from outside the carb; they tend to stick over years of sitting on the shelf, then no amount of cranking will get fuel into the carb unless you unstick it first. Then stick the straw of your spray oil right up against the inlet needle seat hole and give a good shot. Another good long shot where the accelerator pump stem enters the air horn, so it will flow down and wet the pump cup. Another good shot down through the angled internal bowl vent tube where it will flow down and wet the step-up rods and piston. Then operate the throttle lever a few times to spread the oil on the accel pump cup, bolt the carb onto the engine with the correct thick base gasket, and start 'er up.
        • AJ/FormS
          21,740
          8977
          Jan 19, 2014
          Local Time:
          3:41 PM
          ^^ what he said
          If you are not familiar with carbs, this is an excellent alternative.
