1. dodgy
    dodgy Well-Known Member
    228
    314
    Sep 25, 2019
    Australia
    Local Time:
    5:45 PM
    Hi there, i have a new mechanical Autometer oil pressure gauge that reads accurate but very slow to react, it's fed by a copper line that isn't kinked but seems to be smaller in diameter than the nylon tube supplied with gauge, i will change the feed line to check if it's the problem but just wanted to ask first if anyone has come across this before, i put an old test gauge to the same port and it reacts normal.
    Link to slow gauge video
  2. Dana67Dart
    Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member
    8,264
    5788
    Jul 16, 2017
    Northern Colorado
    Local Time:
    12:45 AM
    I would say there is a big restriction in the system some where, maybe even in the guage. It is acting like a thermal guage.
    • Agree Agree x 1
    • d1970
      d1970 TODAY IS A GOOD DAY TO HAVE A GOOD DAY
      439
      260
      Sep 29, 2015
      Ontario, Canada
      Local Time:
      1:45 AM
      bad gauge , it should return to zero pressure when the car is turned off and it should build pressure as soon as you start the motor. Like the extra gauge you have. Oil feed line is OK.
      • Agree Agree x 2
      • rustycowll69
        rustycowll69 Well-Known Member
        2,640
        1357
        Feb 19, 2016
        Pacific northwest
        Local Time:
        11:45 PM
        Air trapped in the line?
        • Like Like x 1
        • Agree Agree x 1
        • d1970
          439
          260
          Sep 29, 2015
          Ontario, Canada
          Local Time:
          1:45 AM
          Air in the line does not affect the reading, the air compresses the exact same pressure as the oil and reads correctly.
          • Agree Agree x 1
          • Disagree Disagree x 1
          • 67Dart273
            67Dart273 FABO Gold Member FABO Gold Member
            52,449
            21596
            Oct 14, 2010
            Idaho
            Local Time:
            11:45 PM
            I would suspect debri or a restriction in the copper line "for start" If you can get clear (white) nylon, buy a length of it and a couple compression ferrules and temporarily hook that to the gauge, even if you remove the gauge. Then you can SEE the oil back and forth in the tube.
            Also some gauges have a restriction right at the gauge fitting, and maybe something plugged it or it is defective.
            • Like Like x 2
            • Agree Agree x 1
            • Lord Sparky
              Lord Sparky Well-Known Member
              704
              536
              Dec 2, 2019
              Carlsbad, California
              Local Time:
              11:45 PM
              Air makes needle jiggle.
              • Agree Agree x 2
              • pishta
                pishta I know I'm right....
                21,789
                11213
                Oct 13, 2004
                Tustin, CA
                Local Time:
                11:45 PM
                those oil preasure lines are curved brass tubes in the gauge that "unwrap" under pressure and are connected by a small gear that acts on the needle. if you can take the feed off the gauge and allow it to blow into a cup you can see if it just dribbles out or jets out. if it dribbles out, suspect a kink in copper line. if it jets, then maybe the gauge mechanism is rubbing on something. you can manually touch the sense tube in there and the needle should move with little effort but dont firce it as the tube will bend and the zero will be lost
                • Like Like x 1
                • Agree Agree x 1
                • diymirage
                  diymirage HP@idle > hondaHP@redline
                  26,899
                  25451
                  Oct 12, 2012
                  michigan
                  Local Time:
                  2:45 AM
                  I like it when they jiggle
                  • Agree Agree x 1
                  • pishta
                    21,789
                    11213
                    Oct 13, 2004
                    Tustin, CA
                    Local Time:
                    11:45 PM
                    • Like Like x 1
                    • dodgy
                      228
                      314
                      Sep 25, 2019
                      Australia
                      Local Time:
                      5:45 PM
                      I haven't gotten back to it yet but have taken all the advice onboard and will troubleshoot it till i find the cause.
                      Thanks.
                      • Like Like x 1
                      • rustycowll69
                        2,640
                        1357
                        Feb 19, 2016
                        Pacific northwest
                        Local Time:
                        11:45 PM
                        I like the suggestion something might be blocking the line or inlet aperture of the gauge. I had an oil sender, which read alarmingly low. It turned out PO had used Teflon tape on the sender threads and a Teflon tape booger was blocking the sender inlet.
                      • dodgy
                        228
                        314
                        Sep 25, 2019
                        Australia
                        Local Time:
                        5:45 PM
                        No tape on mine, compression fittings on both ends of the line and permatex 59235 on the npt at block.
                        I did have a look today at the other copper line kit i purchased with the other and it may be the problem, when looking at the ends it looks like they haven't opened up the copper tube before soldering the fittings on, I de soldered this one cut the ends off, cleaned it up and re soldered .
                        Hard to see and take pic off but end of line was terrible.
                      • d1970
                        439
                        260
                        Sep 29, 2015
                        Ontario, Canada
                        Local Time:
                        1:45 AM
                        All the gauge 1/8 oil lines I've used over the years were all compression fittings used for connections. I've never seen an oil line that had soldered fittings. If you used a line that has soldered fittings that could be your problem, if you get some solder on the end of the tube you will restrict the oil flow going to the gauge.
                        • Agree Agree x 1
                        • dodgy
                          228
                          314
                          Sep 25, 2019
                          Australia
                          Local Time:
                          5:45 PM
                          Solder is no where near the end of tube. All good there.
                        • 67Dart273
                          52,449
                          21596
                          Oct 14, 2010
                          Idaho
                          Local Time:
                          11:45 PM
                          Me neither. No solder.
                          • Agree Agree x 1
                          • dodgy
                            228
                            314
                            Sep 25, 2019
                            Australia
                            Local Time:
                            5:45 PM
                            just to clarify the oil line comes assembled with the ends soldered on, these are not the type that have the olives you slip over the tube and compress as you do the tube nut up. It was all i could get at the time.
                          • dodgy
                            228
                            314
                            Sep 25, 2019
                            Australia
                            Local Time:
                            5:45 PM
                            This is after i refitted the ends. Anyhow getting away from the problem my soldering job is not it.
                          • pishta
                            21,789
                            11213
                            Oct 13, 2004
                            Tustin, CA
                            Local Time:
                            11:45 PM
                            Cheap fuel pressure regulators are just turrets with graduated holes in them so your 'small hole' would make for a lazy gauge.
                          • dodgy
                            228
                            314
                            Sep 25, 2019
                            Australia
                            Local Time:
                            5:45 PM
                            Yep just looking for my nylon tube to put that theory to rest
                          • dodgy
                            228
                            314
                            Sep 25, 2019
                            Australia
                            Local Time:
                            5:45 PM
                            Ok so gauge is good , hooked up the nylon line and worked as should, i then hooked up the other copper line that i improved and symptoms came back , so anyone in Australia don't buy autobarn's copper line kit.
                            Thanks to all who gave their thoughts of what it could be.
                            • Like Like x 1
                            • 4spdragtop
                              4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
                              32,844
                              14076
                              Aug 28, 2009
                              Wasting time here
                              Local Time:
                              1:45 AM
                              I've used the plastic line for years with zero issues. I think the stories of them failing are exaggerated or mistakes made on installation.
                            • dodgy
                              228
                              314
                              Sep 25, 2019
                              Australia
                              Local Time:
                              5:45 PM
                              Yeah me too , while in the local parts store i spotted the copper line and thought yeah why not--- well i know now, don't buy the cheap ones.
                              • Like Like x 1
                              • diymirage
                                26,899
                                25451
                                Oct 12, 2012
                                michigan
                                Local Time:
                                2:45 AM
                                i betcha 90% of failures run the line to close to the exhaust and melt it more then they think
