Small ball joint vs big ball joint
barracudakid
king nc
I have a new pair of lower big ball joints 73 duster.
Will they work on a 69 barracuda SBP
Kelsey Hays disc brakes?
I may be incorrect but believe the bolt hole distance is different to the spindle.
Upper ball joints are large and small. Lower ball joints all have the same size stud. Their difference is in the bolt holes to the spindles.
ALL Lower control arms are the same thing from 1962-1976.
The only difference is if you have a sway bar, then tabs are welded on for 1965-72 sway bars, and then 1973-76 sway bars.
Ball joints bolt to the spindle, (knuckle) and the ball joint stud goes thru the lower control arm.
Spindles are different for 9 inch drum brakes, 10 inch drum brakes, 65-72 KH disc brakes, 73-76 drum brakes, 73-76 disc brakes.
