small block engine mount
Suspension, Steering and Chassis
  1. crazy 340
    crazy 340 Well-Known Member
    789
    32
    Jan 6, 2008
    quebec canada
    Local Time:
    12:55 AM
    wondering whats you are using as engine mount
    I have the qa1 cross member and was using the napa engine mount
    but they are so soft , the engine is bouncing around under the hood
    and Im affraid they gonna split apart so ...
    I know mancini racing and other are selling rod to avoid that but
    Im sure there is mont that will keep my engine under the hood at the right place
  2. Darter6
    Darter6 Well-Known Member
    3,732
    848
    Jan 16, 2008
    Nevada
    Local Time:
    9:55 PM
    Schumacher Creative Services "Poly Loc" mounts. Also PolyBushings.com
    I was looking for new Poly engine mounts for a 64 dart Slant 6 and PolyBushings had them.They have most all mounts,bushings etc for Mopars.
    • Thanks! Thanks! x 1
    • pishta
      pishta I know I'm right....
      13,732
      3459
      Oct 13, 2004
      Tustin, CA
      Local Time:
      9:55 PM
      those A's could be made if the weld doesnt melt the poly filler. interesting approach.
    • 340doc
      340doc Well-Known Member
      2,018
      518
      May 8, 2010
      Hollywood Fl
      Local Time:
      12:55 AM
      I've the poly loc in my Dart for 17 years, motor stays quite still with a choppy cam.
      • Like Like x 1
      • 72SwingerJosh
        72SwingerJosh Well-Known Member
        384
        290
        May 20, 2016
        Pennsylvania
        Local Time:
        12:55 AM
        These are rubber so don’t vibrate like poly or solid mounts and have a lock built in them so they can’t tear.
        Mancini Racing Mag Mount Set
      • AJ/FormS
        AJ/FormS The end is near FABO Gold Member
        15,044
        4184
        Jan 19, 2014
        South-Central Manitoba,Canada, 900ftelevation
        Local Time:
        11:55 PM
        I use the factory biscuits but with a Schumacher restrainer. My hood hardly vibrates at all,lol. My biscuits are from the 70s, double lol.
      • crazy 340
        789
        32
        Jan 6, 2008
        quebec canada
        Local Time:
        12:55 AM
        Im going with the one from schumaker with the lock in them
        • Like Like x 1
