small block oil pan FYI
Early A-Body Discussions
  1. 66dartman
    66dartman Well-Known Member
    1,165
    6
    Apr 25, 2005
    Littleton, CO
    Local Time:
    9:35 AM
    The KEVCO small block 318-340 6qt oil pan will not fit without modifying the K-frame on the front pass. side. It is listed to fit all chassis that take a center sump pan, but they must not have tried it in an early a. Does anyone know how the Moroso 8 qt 360 pan fits the early A? When I build my 408 I don't want to go through this again installing the engine.
  2. Locomotion
    Locomotion Well-Known Member
    2,932
    468
    May 31, 2004
    Florida
    Local Time:
    11:35 AM
    That sounds similar to a Milodon 8 qt pan. The k-member needs a notch cut out of it for ther right front corner of the oil pan. I believe it barely clears in the car, but installation and removal of the engine with the pan requires the notch. This is on later a-bodies.
  3. 396 Signet
    396 Signet Well-Known Member
    417
    9
    Mar 12, 2008
    Pittsburgh, PA
    Local Time:
    11:35 AM
    The low profile Milodon fits perfectly if you shave an inch off the corners. Why go the more difficult route of notching & potentially weakening the K?
  4. 63dartman
    63dartman Well-Known Member
    2,241
    14
    Dec 11, 2005
    rio rancho, nm
    Local Time:
    9:35 AM
    When you talk about the early a all bets are off:)
  5. abodyjoe
    abodyjoe Well-Known Member
    20,710
    5885
    May 22, 2004
    Berlin,N.J. 08009
    Local Time:
    11:35 AM
    Seems everything listed for abodies are for 67-up
  6. Locomotion
    2,932
    468
    May 31, 2004
    Florida
    Local Time:
    11:35 AM
    The notch in the k-member is not enough to worry about. It's confined to the lip area, not in the boxed area. But welding a bead across the cut section would be a lot easier than cutting up a nice oil pan!
    Besides, I like the fact that the 8 qt. is flared and a little shallower than the Moroso, but deeper than the 7 qt. Milodon Lo-Pro. The only down-side to the Milodon 8 qt. is that TTI headers are one of only 2 or 3 conventional headers that will work with it. Milodon may have addressed that problem with their 7 qt.
  7. moparlee
    moparlee 64 Valiant
    1,380
    33
    Aug 18, 2004
    Joplin, Mo
    Local Time:
    10:35 AM
    Moroso's doesn't hit anywhere on mine.
  8. 66dartman
    1,165
    6
    Apr 25, 2005
    Littleton, CO
    Local Time:
    9:35 AM
    I have been out there notching the K frame. I am also going to weld in reinforcement at the notch just in case. The angle of the rf corner of the pan hits the bend in the K frame hard, so maybe the Moroso doesn't have as shallow an angle. Would love to post pics, can't get my Vista to upload.
  9. pettybludart
    pettybludart Well-Known Member
    15,687
    122
    Jul 18, 2008
    Ontario,Canada
    Local Time:
    10:35 AM
    Would love to see pics of where your notching,as I will need to be doing this in the near future.Maybe someone can chime in and upload the pics for you.I,m not so good at uploading sent pics through e-mails,otherwise I would help.Thanks
  10. 66dartman
    1,165
    6
    Apr 25, 2005
    Littleton, CO
    Local Time:
    9:35 AM
    RH side, rear corner where the bend is, that's where I had to cut a notch and box it in. Got the engine in, but the notch should have been bigger. 2" forward from the rear would be better. My pan will probobly hit if the motor shakes(which I'm sure it will) but at this point I'm going to run it. Temporary engine installed until the 408 get's built.
