Small block oil pans
Scotty
Active Member
I'm in the market for a new oil pan and couldn't remember which one would give me the least amount of grief. Was it the Moroso or the Milodon pan that everyone likes so much?
I think I read the moroso has a better fit and the Milodon gets close to the k-frame.
Is that the one that has a single square sump?
Hey, Brett... got a part number??
mor-20710 summit 169.95 plus you'll need their pick up. The pick up will need some modifying with the stroker set up.
If you have main studs and a windage tray be prepared with the morroso you will have the clearance the pan to take the studs
I installed my oil pan and helped assemble the 416 and we had a little trouble with the windage tray and had to bend the pick up tube a bit to make it sweet.
