SS Lancer
Other than a Melling high volume oil pumps what other options are available for in pan pumps for high rpm engines.
@Bighead440 do you know what part # to look for on ebay ?
U selling these ?These are some old Milodon parts that apply:
Thank youI gotta find an old enough MoPar Performance catalog, they are at home and I'm at the shop. The MP/Direct Connection one was anodized blue and shaped like a Pentastar, unlike the round Milodon ones I posted the pictures of.
I like the old Milodon stuff u posted probably be hard to impossible to find.These are some old Milodon parts that apply:
Ten 4That's it!! Your handbook shows the pipe extension and all! I am keeping these, but I may have a spare. I will try and post the MP/DC part number when I get to my old catalog stash so you can search Ebay and other online sources.
Got chaI got these in individual Ebay auctions over the years, you have to be diligent. Most people that have them and list them for sale have no idea what they are used for..LOL!
Ebay has a single part now Im watching it but its not complete I believe.Got cha
Ok I understand about finding odd stuff when I get part numbers I will start horting up some.
Good optionAre you running a rear sump/truck pan? If so, the Direct Connection kit with long (HV) gears and a special recessed billet cover. It fits on any stock or standard M-72 replacement pump housing/body. You plug the pump pickup inlet with a pipe plug and then fab a pickup screen DIRECTLY feeding the gears through the cover. Pick pipe length and strainer to suit the sump. Those covers show up on Ebay all the time.
I have a little time to find kitThey have a cover I see, which you could modify with the bottom inlet using an aluminum pipe bung TIG-welded in the strategic spot.
Can you run a truck sump pan in a abody with orginal k frame?
