Mgc340
applications. New $80
I have two 904 deep stamped tranny pans. $25 each
I have three small block roller cams for sale. $175 each see cam specs I pics. I can pm pics of cams if interested. (2 cams sold )
904 shorty tail shaft conversion (for dragster?) cool piece has gm spline shaft. $400
I have four timing chains. Most are dyno time only or very little street use. $30 each (All sold)
Melling high volume oil pump with truck pan pick up. Dyno time only. $60
Melling high volume oil pump. Used very little $50
Small block distributor $25 Sold
Hughes 904 locking dipstick used. $40
Small block valve covers $25
R3 block valley cover 9.0 deck.$50. Sold
8 3/4 yoke small u-joint $45
Tuff stuff small block starter new mock up only $100
Weld black center caps. $20
R3 block Milodon windage tray studs. $45
Fluidamper for small block. Sitting for a long time it’s almost new but looks worse. $150 (sold)
Forged small block rotating assembly .$900
The specs are:
like new less 1000 miles on assembly!
345 ci .020 over 340
The rotating assembly has been balanced
Eagle forged 3.331 stroke crankshaft
340 mains
Eagle H beam rods 6.125 length
Small end is .927 and big end is 2.100
Part# Crs6125b3d
Custom forged Diamond pistons
4.060 bore
Compression distance 1.910
1/16 1/16 3/16 ring pack
.927 pins
Weight 558
4032 forged
Bobweight 1973
Top of the pistons are dirty with carbon. Just as they were when pulled form engine. No issues at all with assembly.
Small block roller lifters. $250
Milodon 340 main dragster/chassis oil pan with pick up and HV oil pump $325
Thanks for looking. If Can pm more pics
The specs are:
340 mains
Part# Crs6125b3d
4.060 bore
.927 pins
Weight 558
4032 forged
Bobweight 1973
