[FOR SALE] Small Block Rocker Arm Shafts for Adjustable Rockers - New
Mopar Mechanical Parts For Sale
  1. Rocket
    Rocket FABO Gold Member FABO Gold Member
    2,295
    385
    Apr 22, 2005
    U.S.A.
    Local Time:
    3:36 PM
    Contact Seller
    I have a new set of small block Mopar rocker arm shafts for LA type cylinder heads. These shafts are made here in the U.S.. The shafts are made from thick induction hardened steel. They feature banana groves and oiling holes that are positioned for the loading of mechanical rocker arms. These shafts have screw in end plugs for inspection and easy cleaning, inspection or if desired to plumb in an oil line. These are drilled on center for the hold down bolts and are for use with stock small block Mopar heads (273, 318, 340 & 360) or aftermarket cylinder heads including Edelbrock RPM, Indy LAX or other similar shaft mounted cylinder heads where mechanical rocker arms are being used. These are not intended for W2 or W5 heads that use offset drilled shafts and stands.
    These shafts will provide the proper oiling to high load areas for adjustable iron and aluminum adjustable rocker arms to minimize wear and maximize performance and parts life. They are far thicker and stiffer than stock or may aftermarket shafts to minimize flex with stiffer aftermarket valve springs.
    Price is $180 for the pair shipped within the lower 48 states. I can ship internationally for the additional shipping cost.
    PM me with any questions.
    • Like Like x 5
    • Rocket
      2,295
      385
      Apr 22, 2005
      U.S.A.
      Local Time:
      3:36 PM
      Bump
    • Rocket
      2,295
      385
      Apr 22, 2005
      U.S.A.
      Local Time:
      3:36 PM
      Bump
    • Rocket
      2,295
      385
      Apr 22, 2005
      U.S.A.
      Local Time:
      3:36 PM
      Bump
    • Rocket
      2,295
      385
      Apr 22, 2005
      U.S.A.
      Local Time:
      3:36 PM
      Bump
    • Rocket
      2,295
      385
      Apr 22, 2005
      U.S.A.
      Local Time:
      3:36 PM
      bump
    • 1Badcolt
      1Badcolt Well-Known Member
      3,345
      1648
      Mar 15, 2013
      Georgia
      Local Time:
      10:36 AM
      I will get myself a set for Christmas !!!
      They will be just right on those Bloomer heads.
    • Rocket
      2,295
      385
      Apr 22, 2005
      U.S.A.
      Local Time:
      3:36 PM
      More sets available
      • Like Like x 1
      • Rocket
        2,295
        385
        Apr 22, 2005
        U.S.A.
        Local Time:
        3:36 PM
        Bump
