Small Block Water Pump Bypass Hose 360 LA?
Heating / Cooling / AC
  1. coalman
    coalman Well-Known Member
    932
    217
    Aug 6, 2015
    Texas
    Local Time:
    4:50 AM
    I am having a real hard time finding the correct inside diameter hose. The one I have appears to be 5/8" ID. Does this sound correct?
  2. MoparMike1974
    MoparMike1974 FABO Gold Member FABO Gold Member
    2,201
    1521
    Jun 16, 2017
    Maryland
    Local Time:
    5:50 AM
    I like the MP ones, they are black but have a silicon liner that seals and lasts much longer than regular rubber ones.
    • Agree Agree x 1
    • coalman
      932
      217
      Aug 6, 2015
      Texas
      Local Time:
      4:50 AM
      Where do you get them, and am I correct on the size? Thanks
    • lemondana
      lemondana BlackDart
      394
      198
      Dec 7, 2007
      Southeast NE
      Local Time:
      3:50 AM
      It all depends on your water pump and your intake manifold bypass size. The cast iron water pump 69 and earlier use the smaller hose. You just have to juggle hose nipple sizes so you have the same on the WP and the intake
      • Agree Agree x 2
      • coalman
        932
        217
        Aug 6, 2015
        Texas
        Local Time:
        4:50 AM
        They both are the same 3/4" behind the lips, I tried a 3/4"ID and it was pretty loose. Thanks for reply..
      • coalman
        932
        217
        Aug 6, 2015
        Texas
        Local Time:
        4:50 AM
        Is this a Mopar P/N? s-l400.jpg
      • Dicer
        Dicer Diceman FABO Gold Member
        1,087
        1435
        Jan 12, 2016
        Land of Lincoln
        Local Time:
        4:50 AM
        MFR/PN 63735
        Google : 63735 hose
      • lemondana
        lemondana BlackDart
        394
        198
        Dec 7, 2007
        Southeast NE
        Local Time:
        3:50 AM
        The one you have in the picture above is the large one 63735. If that is to big you need the 63642. These are old Goodyear numbers which are now Continental, which is available on Rockauto and I'm sure at your local parts stores. With that in mind you must have a cast iron water pump and the smaller nipple in the intake. Let us know what exactly you are working on-what type of intake?
      • Thomas Dennis
        Thomas Dennis Well-Known Member
        166
        79
        Oct 31, 2019
        Hudson FL
        Local Time:
        5:50 AM
        Have you tried Mancini Racing
      • coalman
        932
        217
        Aug 6, 2015
        Texas
        Local Time:
        4:50 AM
        The inside diameter is 1" for the 63735 hose which is not what package states, found out the hard way. I guess the smallest ID you can get is 0.81. Thanks for replies and the help. Mancini has a hose kit, but no ID stated.
      • coalman
        932
        217
        Aug 6, 2015
        Texas
        Local Time:
        4:50 AM
        I gave up, I decided that it was the location of the outlet in the Air Gap intake and the height of my water pump fitting was the main issue. I am going to install a 90 degree hose barb on the pump and run a piece of 3/4" heater hose between the two...
        • Like Like x 1
