I have a Holley Sniper 2 and Hyperspark on my moderately-built 360 with a 5-speed. It runs great on a cold startup, but after its runs for 15 or more minutes and it warmed up if I shut it off and restart it (like stopping to fuel up) it will stumble and frequently die when it drops down to idle (almost like a vacuum leak). If it fully cools down and I start it, there are no issues.
Details:
-I run Holleys in-tank pump that doesn't require a return line.
-Fuel line is Holleys 3/8 in hose from tank to EFI
-I have the Sniper PDM module in place
-I get 51 pounds of fuel pressure right at the EFI fuel intake.
-I did have to change the EFI temp sensor to go in a smaller port on my Edelbrock Performer RPM manifold to accommodate my AC compressor. It's a unit made by an aftermarket seller that Holley suggested (and has good reviews).
-Car temp stays at a pretty constant 180 and never climbs over 190.
I am considering switching out the aftermarket temp sensor thinking it may be the issue, but that's just a guess.
Any ideas/suggestions?
Details:
