ValerianMagnum
the little car that could
So i decided to buy my engine for my cuda , 1971 cuda , 4 speed trans , 3.23 rear or more minimum...the engine is a late 71 casting and its very nice inside...got the crank / rods and a set of 30 over 318 pistons ifi wanted to oversize , its basicaly a short block , clean solid one...but new to La and always had 5.9 magnums , i want a low budget engine dont mind if it has 300 hp but i want a high rpm 6000 screamer and a fun reliable engine...not a turd that cost me 5-6k and overtheats in 10 mins traffic.....were do i start from here...a 100$ 318 short block...to replace my missing 340 that i never had with the car. Thank you guys
I used factory valve train, yes stamped steel rockers, pushrods, and a normal hyd lifter with a hyd flat tappet cam and hit 7k more than once in my 340. I shifted it at 6k because it ran the best ET there. That engine never had valve train/cam failure after several years. Had it in a Demon, a Dart Sport, D100, and lastly a Duster. Now, your recommendations are good ones, but I don't know if "need" is in the word in order...
