So Many Rabbit Holes...
Mopar General Discussions
  1. Jesus Chrysler
    Jesus Chrysler Forgiving Sins Against Mopar Since 1983
    270
    216
    Feb 5, 2018
    Ontario, California
    Local Time:
    1:13 PM
    Lately it's been hard to think of a direction for my 67 Barracuda that doesn't turn into a several thousand dollar endeavor.
    Example:
    I would like to purchase some new wheels and tires for the car. Problem is, it's a SBP car. So now I'm into new rear axles and brakes all the way around. I'm in it for close to $3k before I even buy wheels. While I'm tearing everything apart, I might as well do suspension, right? Blamo, there goes another $2k+.
    All said and done, I'll be pushing $10k on tires, wheels, suspension and brakes. This is actually the cheapest rabbit hole I have, the engine/drivetrain and bodywork rabbit holes are both a down payment on a house. I used to think guns were an expensive hobby, LOL!
    Sometimes I have to dial back the daydreaming and just focus on the little things that I need to do to make it driveable and just enjoy the car for what it is. I ought to be happy just driving a big block a body with a 4 speed! :steering:
    • Like Like x 5
    • Agree Agree x 2
    • Pascamp
      Pascamp Well-Known Member
      854
      727
      Feb 27, 2016
      USA
      Local Time:
      4:13 PM
      Yup, that about sums up my Mopar experience so far. Even the simplest things turn into an expensive nightmare. There's always some road block that sends you down a different path...and at the end of that path is a rabid donkey looking to kick your nuts in, and steal your wallet. If you really want to reach the pinnacle of frustration start researching g3 hemi swaps. I swear Chrysler goes out of their way to make things difficult.
      • Agree Agree x 1
      • RustyRatRod
        RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
        73,172
        48655
        Jun 7, 2010
        Georgia
        Local Time:
        4:13 PM
        You're supposed to be able to wave your magic Jesus wand.
        • Like Like x 4
        • rumblefish360
          rumblefish360 So close, yet so far away FABO Gold Member
          41,102
          12576
          Jun 21, 2005
          New York, on a Island
          Local Time:
          4:13 PM
          Just get it up and running. Make it drivable and reliable. Then enjoy!
          The wife has speced a few upgrades that will total around 10K. And thus I said, “Excellent idea! Let me know when you save up the money.” Until then, we are driving the car all over the place. 4 wheel drums, no overdrive. And we’re having a ball. Just driving a little slower & braking a bit earlier.
          • Agree Agree x 5
          • Like Like x 3
          • Jesus Chrysler
            270
            216
            Feb 5, 2018
            Ontario, California
            Local Time:
            1:13 PM
            My Child...
            It runs and drives now but it definitely needs a few essentials to fit the reliable/not rolling probably cause bill. It's just not as sexy to daydream about fixing the brake light and exhaust leak!
            • Like Like x 2
            • RustyRatRod
              73,172
              48655
              Jun 7, 2010
              Georgia
              Local Time:
              4:13 PM
              Sexy? Isn't that off limits for you?
              • Like Like x 1
              • j par
                j par Well-hung Member
                27,884
                15312
                Jul 2, 2014
                Portland Oregon
                Local Time:
                1:13 PM
                I'm terrible about slowly accumulating parts and being patient. But it's possible..
                • Agree Agree x 4
                • el5dart
                  el5dart Well-Known Member
                  591
                  407
                  May 16, 2018
                  memphis, tn.
                  Local Time:
                  3:13 PM
                  and just think youll never recoup the cash you dump into it. im in the same boat for the umpteenth time
                  • Agree Agree x 1
                  • YY1
                    YY1 Well-Known Member
                    7,878
                    3509
                    Oct 11, 2011
                    FL
                    Local Time:
                    4:13 PM
                    "Just" get a 66/67 B body 8 3/4 axle.
                    They can be had complete, without a sure grip for under $250.
                    There will be debate about moving the spring perches, but it will install as is.
                    Even if you pay to have them moved it should be no more than another $100 or so.
                    You will then have a better and more easily upgraded axle and more importantly, big bolt pattern.
                    A front disk conversion in the future can net you big pattern there.
                    You can get 85% of what you need for a disk conversion from a mid 80's 5th Ave.
                    (get the rear wheel cylinders from the same car so the proportioning stays the same)
                    This should also be under $250 from a u-pull.
                    • Agree Agree x 3
                    • Frnknsteen
                      Frnknsteen Well-Known Member
                      547
                      339
                      May 26, 2011
                      Spencer, IN
                      Local Time:
                      4:13 PM
                      I'm in the exact same boat. '67 Barracuda, 400 4spd. I've been looking into exactly the same thing. Best deal I found is Cass at DrDiff. Front disc brakes with everything you need is about $800. $295 for new BBP rear axles with green bearings, add $60 - $120 for Precision or Timken bearing (respectively), plus $350 for new larger rear drums to work with the new axles. Totals about $1500 and then need to get new wheels and tires. He offers a new front suspension rebuild kit for a little over $300.
                      That being said,... he seems to be the most reasonable for the whole package and Cass gets great reviews. I have gotten a lot of stuff from him.
                    • R4Sedan
                      R4Sedan Larry
                      5,246
                      2633
                      Nov 26, 2009
                      Weeki Wachee, Fl
                      Local Time:
                      4:13 PM
                      Been down that hole. Believe I'll keep my head above it for now on.
                      • Like Like x 1
                      • Agree Agree x 1
                      • TrailBeast
                        TrailBeast AKA Mopars4us on Youtube
                        21,710
                        9538
                        Mar 11, 2011
                        Arizona
                        Local Time:
                        1:13 PM
                        Any time we shop the internet for parts it can stack up really fast.
                        Patience, Craigslist, investigation and the pick a part yards can save tons of money.
                        Plus it helps a LOT if a person doesn't have to hire someone to do everything.
                        YY1 hit the nail on the head about upgrading without killing the bank account.
                        Examples would be getting brand new large BP drums on a rear end someone was giving away to get it out of their yard.
                        Or an Edelbrock aluminum intake out of the pick a part for 60 bucks (with the perfectly good Eddie carb on it) for 100 total.
                        Or a guaranteed good 42RH overdrive trans for 125 (with the converter and large yoke)
                        Or a nice condition used Hurst shifter in the original box for 60.
                        • Like Like x 1
                        • Agree Agree x 1
                        • SGBARRACUDA
                          SGBARRACUDA ROY FABO Gold Member
                          20,160
                          8500
                          Dec 7, 2006
                          PLANT CITY FL. and PERRY GA.
                          Local Time:
                          4:13 PM
                          Brin
                          Bring it to me. I'm sure I can do that job for under 10K!
                          • Like Like x 2
                          • Frnknsteen
                            547
                            339
                            May 26, 2011
                            Spencer, IN
                            Local Time:
                            4:13 PM
                            One thing I forgot to mention is that Dr Diff does offer the front brake kit with small bolt pattern rotors. That would allow you to start the conversion without changing everything to big bolt pattern up front, then just replace the rotors to BBP rotors when you do the rear.
                            I thought about doing it that way to break up some of the costs. Only problem I saw was that the disc brake conversion pushes the front wheels out 3/4" per side. With my backspacing on my current wheel, I would be getting pretty close to the wheel well lip. I don't know what the backspacing is on my current rallye wheels (haven't had a chance to measure), but it looks like it would be close. Cass recommends a 4.25 - 4.5" backspacing with the conversion.
                          • SGBARRACUDA
                            20,160
                            8500
                            Dec 7, 2006
                            Local Time:
                            4:13 PM
                            I have the later disc brakes on my 69 Dart with LBP rallye wheels with no problem.
                          • RedFish
                            RedFish Well-Known Member
                            25,023
                            3373
                            Sep 5, 2007
                            Local Time:
                            3:13 PM
                            for example... Not mine but looks decent for the price in the pics...
                            Notice how clean it is, especially interior views. It runs, drives, stops. Every looker wants to get in it. No one has questioned what suspension or brakes it has under it.
                            If you just have to have aftermarket wheels, there are plenty of them that will bolt to your OEM bolt pattern. Just remember you can't see them from the drivers seat.
                            • Agree Agree x 1
                            • Garry in AZ
                              Garry in AZ Building a 9 second Valiant FABO Gold Member
                              368
                              465
                              Jul 13, 2017
                              Mesa, AZ
                              Local Time:
                              1:13 PM
                              I learned many years ago that the car hobby was a great way to spend a lot of money you'll never get back. My "car guy" friends around here have a saying... we build 'em for 40 grand, and sell 'em for $17.5.... But the enjoyment of the build, and driving my finished creation has always made it more or less worthwhile. I look at it this way, some folks spend money on gambling, lavish vacations, expensive jewelry, or what have you. I spend it on cars and motorcycles instead.
                              • Agree Agree x 3
                              • Like Like x 1
                              • Cope
                                Cope Fusing with fire
                                4,963
                                6398
                                Oct 20, 2009
                                San Jose, Ca.
                                Local Time:
                                3:13 PM
                                I got my bbp braks from white pink nitro for like 200 bucks?
                                My rear disks I ordered from summit for 3 something. (Also BBP)
                                new wheels from Jegs, 150 each
                                New tires from summit (now this part hurt a little) 500 for the rear set and 320 for fronts.
                                How the hell did you end up at 10 grand?
                                • Like Like x 1
                                • 451Cuda
                                  451Cuda Well-Known Member
                                  1,911
                                  699
                                  Nov 19, 2008
                                  Port-aux-Français, TF
                                  Local Time:
                                  3:13 PM
                                  I think stage 1 should be just do the minimum it takes to make it drivable, with whatever engine/trans it came with, sbp steel wheels (blasted/painted with chrome lugs looks good and is cheap), stock axle and suspension. Then just save up and do one area at a time as you can afford it.
                                  When you're doing the suspension, buy a setup from another car and rebuild that, swap it on when the time comes. That way you can take your time, blast all the pieces, paint or powdercoat, carefully get it all pre-assembled so you can just slide it under the car and do the swap over a weekend.
                                  Try to keep it running/driving as much as possible. Nothing kills motivation faster than a non-running car that's been sitting for a long time.
                                  • Agree Agree x 2
                                  • YY1
                                    7,878
                                    3509
                                    Oct 11, 2011
                                    FL
                                    Local Time:
                                    4:13 PM
                                    As long as we're talking about 5th Ave parts cars...
                                    ...the 8 1/4 from that car will also work, and get you BBP, but those perches are too far apart to fit like a 66/67 B does.
                                    If you can find a whole 5th Ave cheap.....
                                    You also get all sorts of things as a bonus from under dash light sockets, wiring connectors, headlight switch, and steering column hardware, to factory Moapr made in USA nuts and bolts, especially the odd ball "X and 3/4 inch" lengths.
                                    ...and 15x7 BBP steelies!
                                    ...oh, and roller LA 318 and lockup A999!
                                    • Like Like x 2
                                    • Agree Agree x 2
                                    • j par
                                      27,884
                                      15312
                                      Jul 2, 2014
                                      Portland Oregon
                                      Local Time:
                                      1:13 PM
                                      I had an 8 1/4 held up nicely with my 4 speed and Stroker motor. Feeling it was going to break one day I sold it to build an 8 3/4 489 case that only lasted about 20 passes. I still do wonder if I ever needed to change that rear end? In the end I did build a Dana 60 but still that 8 1/4 did never let me down. I bought it from a friend who got it out of the junkyard and sold it to me for $100. It was out of a Dakota and he just cut the perches off and put them on the bottom. I found a guy on eBay and turns out he was local selling a Sure Grip for it and he installed it for a total of $200. I had $300 into that rear end. And the funny part is I used the drums backing plates for the 8 3/4 and currently have them on my Dana 60..
                                      there's a lot of money to be saved on a lot of stuff you're talking about and some consider that the fun part...
                                      Also all three of those rear ends are ebody width. This really fits the bill for the $200 rims and tires I bought off of Craigslist that came off a 2005 Hemi Magnum. I had to get smaller front tires and also I used originally adapters for the front but then after a while went ahead and got the center's machined out a little so they'll fit over the old style front brake hubs. I guess like everybody's trying to say where there's a will there's a way...
                                      Amen....
                                      • Agree Agree x 1
                                      • YY1
                                        7,878
                                        3509
                                        Oct 11, 2011
                                        FL
                                        Local Time:
                                        4:13 PM
                                        The 65-67 B body 8 3/4 is one inch wider than an A body axle.
                                        It's the closest fit there is without cutting and welding.
                                        The F/M/J 8 1/4 is IIRC not quite an inch wider than the 65-67 B.
                                        It's the next closest fit for an A.
                                        E body is significantly wider, almost as wide as 71-74 B or C body!
                                        • Like Like x 1
                                        • toolmanmike
                                          toolmanmike FABO MODERATOR Staff Member FABO Gold Member
                                          58,929
                                          46086
                                          Jan 18, 2006
                                          Iowa
                                          Local Time:
                                          3:13 PM
                                          You'll have that. As long as it's running make improvements as time and money allow. Start buying parts and then attack the project until it's done.
                                          • Like Like x 1
                                          • SGBARRACUDA
                                            20,160
                                            8500
                                            Dec 7, 2006
                                            Local Time:
                                            4:13 PM
                                            Your right C,E, truck and van are the widest. I have a bunch of those.
                                          • TrailBeast
                                            21,710
                                            9538
                                            Mar 11, 2011
                                            Arizona
                                            Local Time:
                                            1:13 PM
                                            I have a 7.25 one legger in the car right now which is ok for the high gearing and auto trans BUT one of the local guys has a 8.25 Detroit locker A body width in his car and is going with an 8.75 but doesn't have time to do it.
                                            We agreed that I would do the assembly and swap of the 8.75 in trade for the 8.25.
                                            So a day or so of my time gets me a Detroit locker 8.25 with 3.55 gears.
                                            AND I'll already have the tools out to do mine.:D
                                            I think I can do both cars in a weekend.
                                            • Like Like x 2
