so what do you guys think
Slant 6 Engines
  1. trudysduster
    trudysduster FABO Gold Member FABO Gold Member
    4,759
    715
    Aug 24, 2009
    Corinth, Ky.
    Local Time:
    7:02 AM
    Just pulled the head off of the slant 6 in my 76 Dart Sport and I believe the head gasket is blown. What do you think. It has been acting funny since I bought it and hadnt time or place to check it out. I am taking the head to the machine shop Monday to have it checked .
    • Like Like x 1
    • mopar56
      mopar56 Well-Known Member
      774
      155
      Jun 19, 2014
      British Columbia
      Local Time:
      5:02 AM
      I THINK, you should show us the gasket! But from what I can see on the head only it looks possible!
      • Agree Agree x 3
      • 413
        413 Well-Known Member
        436
        506
        Nov 13, 2019
        NW USA
        Local Time:
        5:02 AM
        What is the funny stuff the car is doing? I don’t see anything to tell me the head gasket was or is “blown”.
        what do you see that says it is blown?
        yes show good photos of the gasket
        • Agree Agree x 1
        • mopar56
          774
          155
          Jun 19, 2014
          British Columbia
          Local Time:
          5:02 AM
          Well what I see is the 4th and 5th cyl from the left to the right the chamers are both cleaner ( washed ) more than the others, BUT as I already stated with out the gasket it's impossible to tell.
        • trudysduster
          4,759
          715
          Aug 24, 2009
          Corinth, Ky.
          Local Time:
          7:02 AM
          losing ant freeze, sweet smell out the exhaust,loss of power, rough idle, whiteish smoke out the exhaust after the car is at running temp.
        • trudysduster
          4,759
          715
          Aug 24, 2009
          Corinth, Ky.
          Local Time:
          7:02 AM
          I cant tell by looking at the gasket that it is blown or not but by the way this car is acting, smell out the exhaust, losing coolant, smoke out the exhaust etc. From what I have always seen is that it is either a blown gasket or a cracked head allowing the coolant to get in the wrong passage. Here are pics of both sides of the gasket. First 2 pics are one side and last 2 pics are of the other side.
        • MoparMike1974
          MoparMike1974 FABO Gold Member FABO Gold Member
          3,560
          2916
          Jun 16, 2017
          Maryland
          Local Time:
          8:02 AM
          If it were getting in the combustion chamber you should be able to see one or two cylinders thats are much cleaner (whiter) than the rest. Yours all look fairly normal except the far right cylinder which appears to be oil fouled.
          You are burning oil in all the cylinders which indicates poor ring seal or bad valve guides/seals.
          • Agree Agree x 3
          • trudysduster
            4,759
            715
            Aug 24, 2009
            Corinth, Ky.
            Local Time:
            7:02 AM
            How would you explain coolant loss through the exhaust, whitish smoke after reaching temp. and sweet smell out the exhaust. That is what has me puzzled.
          • Max1196
            Max1196 Well-Known Member
            1,074
            890
            May 12, 2016
            Swift Current SK
            Local Time:
            7:02 AM
            ALL of your exhaust ports are "dry", if coolant was being consumed, one or more of those exh. ports should be wet/ discolored/ different. keep looking. I agree with MM74, you need valve guide work/ seals.
          • trudysduster
            4,759
            715
            Aug 24, 2009
            Corinth, Ky.
            Local Time:
            7:02 AM
            Yeah, that is going to be done when the head is in the machine shop.
          • 65-440
            65-440 Well-Known Member
            1,473
            270
            Apr 11, 2010
            va. beach, va
            Local Time:
            11:02 AM
            What do the tops of the pistons look like? Head gasket looks fine to me
            • Agree Agree x 1
            • Dana67Dart
              Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member
              8,244
              5776
              Jul 16, 2017
              Northern Colorado
              Local Time:
              6:02 AM
              Might have had a leak on the intake if /6 has water that runs through or next to a runner.
              Or a crack in the head.
              I have had 2 blown head gaskets on the same car, the blown gasket was VERY obvious.
              Also green rad fluid was dripping from the exhost.
              • Agree Agree x 1
              • trudysduster
                4,759
                715
                Aug 24, 2009
                Corinth, Ky.
                Local Time:
                7:02 AM
                I am leaning towards a crack in head, but will know next week.
              • mopar56
                774
                155
                Jun 19, 2014
                British Columbia
                Local Time:
                5:02 AM
                Well I don't see any obvious signs on the gasket either, based on your symptoms I would maybe lean towards a possible crack BUT again no obvious signs of water in the exhaust through the ports did you have to add fluid to the rad at any time?
                • Agree Agree x 1
                • mopar56
                  774
                  155
                  Jun 19, 2014
                  British Columbia
                  Local Time:
                  5:02 AM
                  Edit.....I just re-read your earlier post you said " loss of coolant" , guess we will see what the machine shop says.
                • MoparMike1974
                  3,560
                  2916
                  Jun 16, 2017
                  Maryland
                  Local Time:
                  8:02 AM
                  When coolant or water enters the combustion chamber it basically steam cleans the cylinder and it will be much cleaner. Typically it will leave a white residue behind. If there was enough to be able to smell it in the exhaust, you should see some sign of it in the combustion chamber.
                  • Agree Agree x 3
                  • AJ/FormS
                    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
                    22,054
                    9224
                    Jan 19, 2014
                    South-Central Manitoba,Canada, 900ftelevation
                    Local Time:
                    7:02 AM
                    Go to your tailpipe, and swab your finger around it, then taste the residue; Antifreeze will taste sweet.
                  • 413
                    436
                    506
                    Nov 13, 2019
                    NW USA
                    Local Time:
                    5:02 AM
                    the gasket doesn’t look blown from here. As stated, Cylinders and ports don’t look like water has been in there. What does the oil look like? Any milkshake in there?
                    • Agree Agree x 1
                    • trudysduster
                      4,759
                      715
                      Aug 24, 2009
                      Corinth, Ky.
                      Local Time:
                      7:02 AM
                      oil is clean. no milky stuff
                    • inertia
                      inertia Well-Known Member
                      3,647
                      930
                      Feb 4, 2011
                      Victoria B.C. Canada
                      Local Time:
                      5:02 AM
                      A J - ! ! . .lol
                    • trudysduster
                      4,759
                      715
                      Aug 24, 2009
                      Corinth, Ky.
                      Local Time:
                      7:02 AM
                      well, I got a call from the machine shop yesterday telling me the head was ready for pickup. They said no cracks. They said the head actually looked really good. I had it milled a little, seats put in and a valve job. So, either the head was a little wharped allowing coolant to escape some, I dont know. Going back with new gaskets, head reworked, we will see what happens. I dont know
                    • mopar56
                      774
                      155
                      Jun 19, 2014
                      British Columbia
                      Local Time:
                      5:02 AM
                      Well I would think if yhe head had been a bit warped the machine shop would have seen that and said something, so at least you have covered the bases, head done new gaskets I'd put in a new thermostat and put it back together.
                    • trudysduster
                      4,759
                      715
                      Aug 24, 2009
                      Corinth, Ky.
                      Local Time:
                      7:02 AM
                      exactly what I am going to do.
