[SOLD] Solid state IVR
moparmat2000
Grand Tetons
I have 4 solid state IVRs i have made. Not sure if anybody is interested in these. The one with ring terminals is for rallye dash clusters, the one with spade connectors is for standard dashes. If you have a rallye dash, you will have to disable the mechanical regulator thats inside the fuel gage while leaving the gage part alone. Standard non rallye dash this is plug n play.
Both applications will require you to make an grounding attach point for the voltage regulator mounting tab, use a finned heatsink, and use white heatsink grease on the back of the voltage regulator because it will get hot under load. You will also have to locate the voltage in, voltage out, and ground on the circuit board. If not sure, take a simple pic of the back of the cluster and i can figure it out for you. All the rallye clusters are the same, i have those figured out.
Red is voltage in 13.5V
Black is ground
Yellow is voltage out 5V
Price is $25 shipped lower 48. Located in west Texas. I accept paypal
get em before Joey shuts him down , ask Ben at DemonIVR about selling those here and his were complete with heat sink drilled for mounting .
I really thought there would be more interest in these, so I made a few more. I have a total of 6 to sell. Once they are gone i'm done.
I got mine...thx
Anyone one that has their dash out should do this upgrade before reinstalling.
It sure beats the agony of messing with an installed gauge repair.
