spark plug gap
thanson_mopar
Black Hills, South Dakota
the spec for small block spark plug gap was .35 correct? Maybe this is a dumb question but my engine is not stock, i run mopar chrome box with aftermarket coil, since I have more available volatage to jump the gap than stock should I run a longer than stock gap on the plugs?
I run a .040 plug gap. I ran this with the MoPar chrome box and now with the MSD ignition. Seems to work well.
Fred B
You should be able to go as far as .55 believe it or not, however, I doubt you'll find a gain with it there that wide. Best test is at the track until performance falls off. .40 is a safe bet for now.
In the MSD instruction manual there's a chart that tells you what plug gaps to use based on your comp. ratio. I have stock pistons with MSD box, coil, and dist. and my 360 seems to like .45 just my two cents
