Spark plug opinions
Small Block Mopar Engine
  1. Jonnylightening
    Jonnylightening Well-Known Member
    510
    103
    Mar 4, 2012
    Pennsylvania
    Local Time:
    4:15 PM
    Pulled my plugs and to me they seem good but wanted opinions. What do you guys think? Any changes I should make? 20210721_200250.jpg
  2. crewchief
    crewchief A & P Mechanic FABO Gold Member
    545
    263
    Jan 17, 2014
    Malta NY
    Local Time:
    5:15 PM
    How many miles on them? Seems to be firing well, good color on the insulator.
  3. Scody21
    Scody21 Just send it
    516
    412
    Jul 17, 2019
    Southwest Washington Coast
    Local Time:
    2:15 PM
    What brand and number plugs are you running?
  4. Jonnylightening
    510
    103
    Mar 4, 2012
    Pennsylvania
    Local Time:
    4:15 PM
    Maybe 40 miles if that. Running good vp110 gets pricey
  5. Jonnylightening
    510
    103
    Mar 4, 2012
    Pennsylvania
    Local Time:
    4:15 PM
    Autolite 3924
  6. Scody21
    516
    412
    Jul 17, 2019
    Local Time:
    2:15 PM
    Is VP 110 leaded gas? Timing seems alright. Not seeing much heat into the threads. Maybe a touch lean..
  7. crewchief
    545
    263
    Jan 17, 2014
    Malta NY
    Local Time:
    5:15 PM
    Yes, but what a fuel!
  8. Jonnylightening
    510
    103
    Mar 4, 2012
    Pennsylvania
    Local Time:
    4:15 PM
    Yessir! Maybe a step up or 2 on the jets?
  9. Jonnylightening
    510
    103
    Mar 4, 2012
    Pennsylvania
    Local Time:
    4:15 PM
    It's for sure good stuff! Local to me it's $10.50/gal
  10. Scody21
    516
    412
    Jul 17, 2019
    Local Time:
    2:15 PM
  11. flyfish
    flyfish C8H18+N2O = :-D
    2,380
    993
    Apr 16, 2007
    Indy
    Local Time:
    5:15 PM
    10.50/gal....ouch....Do you have e85 near your? If so, converting to e85 would pay for itself in 1 summer of driving, no joke (a little over $2/gal).
  12. Jonnylightening
    510
    103
    Mar 4, 2012
    Pennsylvania
    Local Time:
    4:15 PM
    No doubt. I think over the winter I'm gonna get parts lined up
  13. furrystump
    furrystump Well-Known Member
    1,344
    880
    Nov 13, 2004
    Local Time:
    10:15 PM
    You can get an angle grinder with cut off disc. Cut the crimp right above the hex and pull the porcelain right out. Easy to see the WOT part throttle. This is NOT an example of good plug.
  14. furrystump
    1,344
    880
    Nov 13, 2004
    Local Time:
    10:15 PM
    VP 110 is leaded fuel.
  15. Jonnylightening
    510
    103
    Mar 4, 2012
    Pennsylvania
    Local Time:
    4:15 PM
    Took it to the track and it started missing pretty good so I left off of it. Pulled the plugs again when I got home. They weren't white which was a relief but they were starting to glaze. I changed the plugs and took it out on the road and flat footed it. No miss and actually pulled me into the seat harder then it did at the track. So I'm thinking the plugs fixed it. Before I was running Autolite 3923s and the plug in the pic is the ones I had laying around. They are Autolite 5224s. Still some fine tuning but well see what happens the next go round.
  16. furrystump
    1,344
    880
    Nov 13, 2004
    Local Time:
    10:15 PM
    I run cheap autolite 65’s. Cheap so I change them just on a whim.
