1. vernfields jr
    vernfields jr Well-Known Member
    119
    9
    Mar 16, 2005
    Local Time:
    6:00 PM
    ok I'm only getting spark when I turn the key off. What have I done wrong. Please help
  2. brian6pac
    brian6pac Well-Known Member
    3,465
    1972
    Nov 15, 2016
    N.E.Ohio
    Local Time:
    1:00 PM
    it wont start or run ? no volts on coil + ? key in off 12v at coil. Is this what you are saying?
  3. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    10,443
    1290
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    12:00 PM
    ..............change the ballast resistor..........kim....
  4. vernfields jr
    119
    9
    Mar 16, 2005
    Local Time:
    6:00 PM
    Yes brain6pak. I reversed the coil wires and now it runs but sounds like shit. I am running the FBO ignition so the ballast is by passed oldkimmer. Now when I stop cranking or running the coil sparks about 10 times. I'm so confused
  5. brian6pac
    3,465
    1972
    Nov 15, 2016
    N.E.Ohio
    Local Time:
    1:00 PM
    the coil has a + and a - you can't reverse them, + has 12 volts or less with a ballast the - goes to your ignition module. coil + should be 0 volts in off, if not you are getting feedback voltage from somewhere.
    • Like Like x 1
