Specs On Old Lunati Max Wedge Cheater Cam
Big Block A body Tech
  1. 12many
    12many Well-Known Member
    1,880
    2300
    Dec 14, 2016
    South Carolina, Thank God
    Local Time:
    6:40 AM
    Was wondering if any of the years in the game members here have any recollection of the solid Lunati max wedge cheater cam (as run in NHRA SS) and it's specs? Not sure if there were variants of it, or if it was one particular spec'd cam through the years? Just reminiscing about the first time being around max wedge cars, and a bad combo I put together (pure race cam on the street= cracked heads) at the wet behind the ears age of 19, I recall the lobes looking like bloated eggs. No info online that I can find. Thanks
    • Like Like x 1
    • RustyRatRod
      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
      73,370
      48893
      Jun 7, 2010
      Georgia
      Local Time:
      7:40 AM
      @Bighead440 might have some info. He's pretty sharp about this kinda stuff.
      • Like Like x 1
      • Thanks! Thanks! x 1
      • Bighead440
        Bighead440 Well-Known Member
        352
        269
        Jun 18, 2017
        Milledgeville, Georgia
        Local Time:
        7:40 AM
        The variations are pretty endless. There are TF and 4spd grinds as well as tweaking of the ramp(?-more like "cliff") speeds by the various grinders. I personally have 2 different Lunati grinds (Stage II) and one Crane, and the .050" numbers are different on all 3 as well as the gross lift and lash specs.
        • Like Like x 1
        • 12many
          1,880
          2300
          Dec 14, 2016
          Local Time:
          6:40 AM
          I kinda figured it wouldn't be that easy. It was a cam I bought back in 85/86, had idea of making a 64 Sport Fury 440 powered mw replica, got it from a max wedge guy who had parts connections/dealings with Dvorak. I know it was for an auto MW engined 64 savoy iirc. That's all I remember, other than it transformed my car into a complete beast until it sprung leaks on both heads due to overheating, the duration being through the roof and all. But it made the popcorn well and was frightening (with a J converter) while it lasted
          • Like Like x 1
          • Bighead440
            352
            269
            Jun 18, 2017
            Local Time:
            7:40 AM
            The lobes on one of my Lunati's are noticeably "square" with a lot of +.300 lobe lift. I think the specs are 268*@.050" and .518" lift with .012" lash. In comparison, I have Cam Dynamics and Comp Cams "Magnum/Commando" hydraulic cheater cams and a Lunati 340/275-290HP cheater cam they look much more rounded ( albeit .458/.467"ish valve lift).
            • dartgarth
              dartgarth Well-Known Member
              141
              67
              Jul 2, 2010
              Langley
              Local Time:
              4:40 AM
              I may have a Lunati book from the early 90's in my archives... I'll need to do some digging to see if I still have it.
              Garth
              • Like Like x 1
              • 12many
                1,880
                2300
                Dec 14, 2016
                Local Time:
                6:40 AM
                Was thinking of that as a possibility. I'd just like to know what the specs were, I had no idea at all other than it was from an actual max wedge Dvorak had run. I now recall him telling the guy I bought it from "it ran (I don't recall but it was quick) so the guy will like it" and later on I asked if it was street able? Reply was "not really".... Ah youth:realcrazy:
              • dartgarth
                141
                67
                Jul 2, 2010
                Langley
                Local Time:
                4:40 AM
                Found a book from 1992."lunati's version of the Stage III 425 HP 426 Wedge cam" 253/253 @.050, 300/300 gross, .520/.520 lift 112 lSA, .028/.030 lash.
                Garth
                • Like Like x 1
                • Bighead440
                  352
                  269
                  Jun 18, 2017
                  Local Time:
                  7:40 AM
                  This is a reproduction based on the actual timing events of a stock cam, a "cheater" is designed to maximize airflow using gross duration figures (SAE) and max lobe lift, but NOTHING else qualifies as stock. LOL
                  • Agree Agree x 1
                  • dartgarth
                    141
                    67
                    Jul 2, 2010
                    Langley
                    Local Time:
                    4:40 AM
                    Ah yes I do recall that now... there is a page in there about NHRA legal stocker cams and how to order them... Perhaps call Lunati, maybe they have something in the archives...
                    • Agree Agree x 1
                    • perfacar
                      perfacar Well-Known Member
                      1,092
                      285
                      Mar 1, 2006
                      renton,wa
                      Local Time:
                      4:40 AM
                      call bullet cams, or comp, cams. ask for stocker cam guy.
