Speedmaster Small block porting tips and results
Mopar Racers Forum
  1. Cudafever
    Cudafever Well-Known Member
    4,016
    1374
    Sep 27, 2009
    Local Time:
    11:06 AM
    The last intake on my experimental head is going to get a 50degree seat. If you have a pressure issue in the combustion chamber. And I think these SM will have, as they grow in cfm. You have to sink the valve or cut the seat to50 to make the air happy. Maybe not. We will just half to see how PBR proceeds with his plans
  2. gzig5
    gzig5 Well-Known Member
    1,157
    1094
    May 3, 2018
    Mequon, WI
    Local Time:
    12:06 PM
    I don't know if I'm behind the curve, but did we get flow numbers after opening up the chamber around the valves and after tubing and removing the push-rod pinch?
  3. Cudafever
    4,016
    1374
    Sep 27, 2009
    Local Time:
    11:06 AM
    I haven’t seen any intake numbers
  4. pittsburghracer
    pittsburghracer FABO Gold Member FABO Gold Member
    3,285
    5879
    Apr 20, 2016
    Freeport, PA.
    Local Time:
    1:06 PM
    I had my bench set up to flow the exhaust side so while it was in that mode I ported the exhaust. Intake numbers coming soon.
    • Thanks! Thanks! x 3
    • MOPAROFFICIAL
      MOPAROFFICIAL FABO Gold Member FABO Gold Member
      5,470
      4450
      Jun 1, 2016
      Beach
      Local Time:
      10:06 AM
      Low lift flow isnt everything just as much as high lift flow isnt everything. It's all important. Getting the most air you can in with the window of lift and time you cam for is the object. Which brings us back to not everything is max effort, hence why the higher low lift compensates for the lack of cam/rpm.
      I don't think he needs a 50° seat to get the numbers he's looking for. That's all I have to say about it till you dig out your econo heads and test those seat angles out on'em and report back with stellar results...then maybe I'll go back to work on those j's and see if 290cfm decides to rear its head in the other 7cyl. One port is special sometimes...strangest thing.
      • Like Like x 2
      • yellow rose
        yellow rose Doctor of Thinkology.
        21,343
        17413
        Jun 19, 2015
        Living on the razors edge
        Local Time:
        10:06 AM
        LOL. Yep. One port can be golden and you can't get the rest happy. Core shift, internal materiel loss...who knows.
        I'm hoping by spring I can get some time on the flow bench. I may not publically post everything I find, but I may PM the results.
        Some things don't need to be public, but I'd share with members of this forum privately for sure.
        • Thanks! Thanks! x 2
        • Cudafever
          4,016
          1374
          Sep 27, 2009
          Local Time:
          11:06 AM
          In my hotel room
          On vacation.
          Waiting for room survive.
          Chop chop!
          ...............yah I’m board.
          • Like Like x 2
          • Cudafever
            4,016
            1374
            Sep 27, 2009
            Local Time:
            11:06 AM
            So I guess the icons/emojis on my tablet are not approved.:soapbox::wtf::bs_flag:
            Oil Well. I got a kick out of it,, but u all won’t.."......
            • Like Like x 1
            • pittsburghracer
              3,285
              5879
              Apr 20, 2016
              Freeport, PA.
              Local Time:
              1:06 PM
              I did lower the shortside a little Sunday (.080) and it responded with 4-5cfm max so we are in the low 280’s at .700 with more on the table.
              • Like Like x 3
              • oldkimmer
                oldkimmer FABO Gold Member FABO Gold Member
                14,917
                3964
                Nov 11, 2006
                Kindersley, Saskatchewan,
                Local Time:
                12:06 PM
                Great. Kim
              • Cudafever
                4,016
                1374
                Sep 27, 2009
                Local Time:
                11:06 AM
                Your going to make me eat my words.......
                :popcorn:
              • 318willrun
                318willrun Utube channel 318willrun
                14,135
                14587
                Sep 13, 2013
                I'm here
                Local Time:
                12:06 PM
                just curious, what anti-freeze do you all plan on running through your aluminum heads?????? Street or street/strip guys (I know, full time race cars will have something different).
              • toolmanmike
                toolmanmike FABO MODERATOR Staff Member FABO Gold Member
                48,627
                33290
                Jan 18, 2006
                Iowa
                Local Time:
                12:06 PM
                Most drag strips require water. Car manufacturers use propylene glycol in their aluminum engines. A combination cast and alloy headed engine should be good with Ethylene glycol.
                • Thanks! Thanks! x 1
                • 318willrun
                  14,135
                  14587
                  Sep 13, 2013
                  I'm here
                  Local Time:
                  12:06 PM
                  Thanks, i agree on the choices. I've never had anyone ask what I had for coolant. 30 yrs of going to the strip.... Always look for the overflow, though. I think they just know a street car will have a 50/50 blend.
                  • Agree Agree x 1
                  • toolmanmike
                    48,627
                    33290
                    Jan 18, 2006
                    Iowa
                    Local Time:
                    12:06 PM
                    Yes, street cars must have a overflow. a hose and a plastic pop bottle atached with a tie strap does the trick. (depending on how anal the tech guy is) LOL
                    • Agree Agree x 1
                    • 318willrun
                      14,135
                      14587
                      Sep 13, 2013
                      I'm here
                      Local Time:
                      12:06 PM
                      Honestly, unless there is somebody new, they don't even look at my cars. In fact, tech was closed the last time I got there a little late and I just went to the tower and they said "you've been here before, you know" and took my card. In 30+ years, I've never put fluid on their track, nor delayed their race. But then, many of the old workers that knew me don't work there anymore.
                      • Like Like x 1
                      • Cudafever
                        4,016
                        1374
                        Sep 27, 2009
                        Local Time:
                        11:06 AM
                        Man.you had better find some wood to knock on:poke::D
                        • Agree Agree x 1
                        • MOPAROFFICIAL
                          5,470
                          4450
                          Jun 1, 2016
                          Beach
                          Local Time:
                          10:06 AM
                          No glass fuel filters either. If they're in a good mood though they will duct tape around it and let you run.
                          • Like Like x 1
                          • toolmanmike
                            48,627
                            33290
                            Jan 18, 2006
                            Iowa
                            Local Time:
                            12:06 PM
                            Haven't seen one of those since our old 55 International pick up. LOL
                            • Like Like x 1
                            • j par
                              j par Well-hung Member
                              22,350
                              11109
                              Jul 2, 2014
                              Portland Oregon
                              Local Time:
                              10:06 AM
                              I've always just ran distilled water and a bottle of Redline water wetter...
                            • rumblefish360
                              rumblefish360 So close, yet so far away FABO Gold Member
                              37,820
                              9512
                              Jun 21, 2005
                              New York, on a Island
                              Local Time:
                              1:06 PM
                              What he said ^^^^^^ at the track, on the street, I take the lazy way out and purchase the 50/50 blend. It’s just easier then getting 100% antifreeze and the getting the distilled water separate.
                            • fishmens67
                              fishmens67 Well-Known Member
                              7,401
                              4682
                              Nov 10, 2012
                              idaho
                              Local Time:
                              12:06 PM
                              Evans waterless
                            • pittsburghracer
                              3,285
                              5879
                              Apr 20, 2016
                              Freeport, PA.
                              Local Time:
                              1:06 PM
                              Johns tap water
                              • Like Like x 3
                              • Agree Agree x 1
                              • yellow rose
                                21,343
                                17413
                                Jun 19, 2015
                                Local Time:
                                10:06 AM
                                LOL you cheap screw!!!!
                                • yellow rose
                                  21,343
                                  17413
                                  Jun 19, 2015
                                  Local Time:
                                  10:06 AM
                                  That's what I use. I'll never go back to anything else. And the track can kiss my ass. They start paying my engine bills and THEN they can tell me what to use for coolant.
                                  • Agree Agree x 1
