Speedometer gear I need ?
MAPS
Montreal, Canada
Can someone please tell me which gear I need to buy to have my Speedo rubbing correctly ?
I have 4.10 rear gears, tire is 27.75 inches tall (i guess you would say 28 inches ?)
Thanks.
MAPS
P.S. If anyone has one for sale, even better...
I'm sure you know about clocking the gear so you dont mess it up ? Here's a link just in case.
Speedo gear clocking
See pic it is lined up with 32-38. That's the teeth count on the gear that is being used. Set the clock at the teeth count that is on the gear you wind up using. If you use the wrong setting your gear either won't touch the gear in the tranny and not work at all or it will be too tight and strip all the plastic teeth on your new gear. Pretty simple actually .
