spindle to LBJ bolts
I agree with Grade 8 hardware comment. However commercially available grade 8 bolts are not the exact length and since the bolt is essentially the steering stop, using a longer bolt will result in a larger turning radius. So if you go with the commercial grade 8bolts cut or grind them to the proper length. I've had no issues when I've used the commercially available hardware and adjusted the length if necessary.
