plymouth67
It be a lot cooler if you did...
Gonna go a different direction here. The stud gun will help you once you get it closer. I'm gonna tell you to do something that will sound crazy but, it works. Find...this is where it gets weird, a football or basketball that will fit up on there deflated, position it where you want it, its has to have some bracing from the inside to push against. Slowly air it up while you are using a body hammer to hammer down the area in the jam where its bulged out next the dent in the jam. Do all this Slowly to relax the metal and I feel like you will be able to get it pretty close then, just metal finish it off.
