[WANTED] Stage 6 spacers
Mopar Stage VI Intake Manifold Spacers
I'm running Stage VI heads as well. Mike at B3 opened 'em up for 2.19 intakes and manufactured the rocker shaft stands to correctly locate the custom spec'd T&D rockers. I used an RB manifold on my B block.
I have a new set of Stage VI rocker stands, but some how one got lost. If your interested. Actually I have the rocker stands.
I just realized what your looking for, Sorry.
Sweet. I run a b block with rb intake, but now have a rb block so I need spacers. Kin
Did you check out the link? Those are the only ones I found aside from using the intake Mopar performance makes specifically for the stage VI's. Are yours the standard stage VI or the Chapman's? I've got the Chapman's, they're real nice! Either way, good luck with the new build!
