1969dodgedartgt
hi guys, my car is currently having some stalling issues. she stalls mainly when sitting a a light or stop sign. no problems when driving. sometimes stalls on backing up. she also sometimes has hard time starting, she'll crank anc crank without ignition.
how can i pinpoint what is the problem?
I had the idle speed up a bit high and it was doing well. but i really didnt like the sound of the higher idle. so I took it back down and shes stalling again.
I also recently changed my fuel filter and found my fuel to be very dirty, I wonder if that might be part of my problem. (the backing up and stalling may indicate this?) she was real good after first replacing fuel filter, but after stilling idle for awhile she started to fade.
I'm doubt she needs a tune up but she might (how do i know? check point gaps and dwell time etc. as if I was just doing tune up but without replacing points, condensor, and rotor?) ( I am debating buying a mopar performance ignition system, instead of tuneup kits over and over)
please help with advice thanks
